It is currently Fri Jul 31, 2026 7:32 pm
Vehicle: Suzuki Jimny 2003
Post Posted: Mon Mar 03, 2014 10:43 am
Hi all,
As the heading suggests what is everyone using as recovery points on there sierra's. I have a 96 coily and I am wanting to put some decent recovery points on but I can't find where I can put them. If anyone can post up some photos of there points or give me some suggestions that would be greatly appreciated,
Pete
Vehicle: sj51
Post Posted: Tue Mar 04, 2014 7:25 am
i bolted hooks through my chassy,
made up a big flat plate washer that slides inside the rail to resist it pulling though
Post Posted: Tue Mar 04, 2014 7:52 am
When I had a look at the front and rear of the chassis on my sj80 I couldn't find any holes to be able to bolt through, or did you drill into your chassis?
cheers
Pete
Vehicle: 1997 Sierra SJ80
Post Posted: Tue Mar 04, 2014 10:42 am
Sierra's don't need recovery points. They never get stuck.
So, you must be putting them on to recover Nissans and Tojos and Jeeps, yeah?
Vehicle: WT sierra, GU CRD
Post Posted: Tue Mar 04, 2014 11:40 am
I wish mine knew that when I got stuck up the hill in my avatar. I was extracted from that one by a GU :oops:
I use the tow bar with the ball removed on the back.
I use the tie down point at the front for light recoveries (which I do not recommend as it can cause damage to the sierra)
If I were you, I'd belt a pipe though the pipe at the front of the chassis, then make some plates with points attached to them, like this:
viewtopic.php?f=14&t=7930&hilit=shep+proof+bar
I love ZD30. :)
Vehicle: sj51
Post Posted: Tue Mar 04, 2014 12:53 pm
cheers
Pete
I just drilled holes to suit
Post Posted: Wed Mar 05, 2014 9:08 pm
My stock coily points have pulled trolls diffed out in mud, not being gun hoe but still got em out
