It is currently Fri Jul 31, 2026 12:28 pm
Post Posted: Tue Mar 11, 2014 3:46 pm
Is there any tricks to remove the flywheel on a g13ba?
I can't get a socket on the bolts and an open end spanner just slips off!
Post Posted: Tue Mar 11, 2014 6:24 pm
Just having a look at a motor sitting outside, looks straight forward
Whats stopping you from getting a socket on?? Is the motor still in the car? Whats in the way?
Vehicle: WT sierra, GU CRD
Post Posted: Tue Mar 11, 2014 6:39 pm
Sounds like it is to me.
I had the engine out and used a rattle gun on it.
Nothing like a bit of finesse :lol:
I love ZD30. :)
Post Posted: Tue Mar 11, 2014 6:42 pm
I've got the engine out. Will post pics tomorrow.
That sounds nothing like a bit of finesse :rofl:
If the motor is still in the car but the gearbox is out you would need to do it from underneath the car. If its not in the car a rattlegun or impact driver would work (if its a stuck bolt problem), just don't snap the bolt..
Post Posted: Tue Mar 11, 2014 6:43 pm
Cool, pics will help us understand the issue
Post Posted: Tue Mar 11, 2014 7:24 pm
Rough gets the job done :twisted: :wink:
In all seriousness, I find using impact on tight bolts does less damage.
If it ruins them when they come out I replace. Doesn't happen often though.
I love ZD30. :)
Post Posted: Tue Mar 11, 2014 7:36 pm
I can't even fit a socket on the bolts!
Post Posted: Tue Mar 11, 2014 7:45 pm
Well they shouldn't be anything special.
I love ZD30. :)
Post Posted: Tue Mar 11, 2014 7:54 pm
They're not. But as I stated there's no room.
Post Posted: Tue Mar 11, 2014 8:12 pm
Mine had plenty of room.
I don't know what to do to tell the truth. If it were me I'd probably be reaching for a chisel and hammer.... and breaking something.
I love ZD30. :)
Post Posted: Tue Mar 11, 2014 8:14 pm
I think I have another flywheel sourced. I only need it for the twin cam swap.
Post Posted: Tue Mar 11, 2014 11:03 pm
They do look pretty close together!! What size socket are they??
Post Posted: Wed Mar 12, 2014 4:53 am
It's a 17mm
Vehicle: LWB Sierra & XL7
Post Posted: Wed Mar 12, 2014 9:21 am
I've never had a problem.
I've always used a rattle gun, or a breaker bar with a screw driver jamming the flywheel so it doesn't move.
In your case you may want to 1) spray WD on it, swear at it and let it sit for a few mins 2) use a thin walled socket, but I've always used an impact socket set, So basically, your weird. :/
Don't use an open end spanner, you'll fuck it and make the job harder than it has to be.
'92 Vitara & Camper trailer
Post Posted: Wed Mar 12, 2014 3:43 pm
Sorry for the delay Dono..
I checked mine and my 17mm socket fits fine. I measured from bolt centre to bolt centre and its around 26mm, I can only think that yours are closer together for some strange reason, or your sockets are fucking massive??
Whats the distance between your bolt centres?
Post Posted: Wed Mar 12, 2014 3:44 pm
Vehicle: Coil Sierra
Post Posted: Wed Mar 12, 2014 6:25 pm
What type of socket are you using?
The 12 point ones seem to have a thinner wall.
Post Posted: Wed Mar 12, 2014 7:30 pm
Tried both and 1/4 inch.
The bearing is sitting out. All good it's sorted now.
Thanks for everyone's input.
Users browsing this forum: No registered users and 95 guests
