It is currently Sat Nov 28, 2026 4:35 pm
Vehicle: 1997 Vitara 2.0
Post Posted: Sun Mar 30, 2014 10:20 pm
Hey could someone explain what this is. Image
Was cleaning some parts today and wondered what this was. Couldnt find anything in the fantastic Haynes haha and iv tried searching the net but its hard when I'm not sure what I'm looking for. But anyway when I took it of it was clogged up on the part and on the intake manifold.
Intake manifold
Part
What does it do.
What would the clogged up holes be a result of and what implications would they have on the car.
Appreciate your help.
Post Posted: Sun Mar 30, 2014 10:33 pm
EGR Valve, you should clean it out and chase out the passageways back through to the exhaust manifold. If it sticks open it causes idling and running problems
Post Posted: Sun Mar 30, 2014 10:41 pm
Thanks!
The valve is clean now and I cleaned out what I could see on the intake side using some MAF cleaner and cotton swabs, so maybe an inch or so inside.
What should I do next, will I need to remove the intake manifold and clean under there?
Post Posted: Sun Mar 30, 2014 10:46 pm
Try starting it up with the EGR valve off and see if it will blow the muck out by itself.
Post Posted: Sun Mar 30, 2014 10:51 pm
Thanks a lot. ill give that a go tomorrow!
Post Posted: Mon Mar 31, 2014 8:54 pm
...just tried that out, car cuts out right away. Tried agaun with a little gas but it sounded horrible, lots of bangs and louds noises - is that normal? No muck came out but I didnt try for long
Post Posted: Mon Mar 31, 2014 9:17 pm
If it doesn't sound bad then the passageway is blocked, so you should be OK, I would just put the EGR back on.
Users browsing this forum: No registered users and 25 guests
