| Fuel filter for sv420 http://auszookers.com/forum/viewtopic.php?f=37&t=45777 |
| Author: | Daly87 [ Tue Apr 08, 2014 12:14 am ] |
| Post subject: | Fuel filter for sv420 |
I ordered this ryco fuel filter for my 1997 sv420. Now the ebay store said its the right model but its different to what I have and the inlet and outlet are different too. I went on ryco website and sure enough its the correct type for my year. ![]() but as you can see it wouldnt fit ![]() ![]() Any idea what I should do/buy... |
| Author: | Sookie [ Tue Apr 08, 2014 12:34 am ] |
| Post subject: | Re: Fuel filter for sv420 |
What's part number on one that's in there now? Get one the same, replace and happy days. One in your vitara now looks a lot like if not the same as what was in my 1997 model g16b vitara had |
| Author: | fordem [ Tue Apr 08, 2014 2:41 am ] |
Just a suggestion - try the Ryco Z464 that the listing shows for the 98~00 SV420. The Ryco listing appears to be incorrect, the Z389 (as shown in your picture) has inlet & outlet pipes - which is what is used on the 98+, and the Z464 has threaded inlet & outlet fittings, so they probably have them reversed. |
| Author: | Daly87 [ Tue Apr 08, 2014 2:24 pm ] |
There is no part number on it at the moment so cannot compare. fordem wrote: Just a suggestion - try the Ryco Z464 that the listing shows for the 98~00 SV420. The Ryco listing appears to be incorrect, the Z389 (as shown in your picture) has inlet & outlet pipes - which is what is used on the 98+, and the Z464 has threaded inlet & outlet fittings, so they probably have them reversed. Thanks. Ill have to order another then. I was thinking that could of happened but wanted to check before I spend another 70+ on another wrong part! Appreciate your replies guys. |
