It is currently Fri Aug 14, 2026 2:29 pm
Vehicle: 98 Coily
Post Posted: Wed Apr 09, 2014 10:02 am
Ordering a transfer case from LROR to fit my coily. From what I can tell after reading every post I could find related to this topic, I am still in need of the exact bolt pattern measurements for the appropriate flanges I'll need (WT if I understood correctly) and/or the size of the bolts. Want to be sure the flanges are correct before they rebuild and ship the case all the way over here...
Thanks for your help.
Vehicle: Drover pickup turk
Post Posted: Wed Apr 09, 2014 10:11 am
want33s wrote:
want33s wrote:
C, 1.3 NT with drum handbrake. 8mm bolts in flanges.
D, 1.3 WT without handbrake. 10mm bolts in flanges.
Are the holes spaced the same, I'm sure I read somewhere that someone had drilled out the NT flange to match to WT, is that true?
Seems forever ago now that I was sourcing all the bits, has become such a common swap now.
The hole spacing isn't quite the same. I've seen NT flanges drilled to WT and it isn't pretty.
I like the tuna here
Vehicle: 98 Coily
Post Posted: Wed Apr 09, 2014 10:40 am
Thanks. I measured the distance between the center of the bolt holes on my coily flanges and came up with 6mm spacing. Can anyone verify that matches the WT spacing?
Post Posted: Wed Apr 09, 2014 11:07 am
i have no idea what the 6mm your talking about it is, but i can tell you 100% that coily flanges are the same as WT
Vehicle: 98 Coily
Post Posted: Wed Apr 09, 2014 11:21 am
Sorry meant 6cm.... But thanks for the confirmation.
Post Posted: Fri Jan 16, 2015 10:04 am
So to dig up an old thread.
Coily flanges would bolt onto a WT transfer?
Post Posted: Sun Jan 18, 2015 6:52 am
Tailshafts bolt to WT transfer flanges with four nuts and bolts
Tailshafts bolt to coily transfer flanges with just four bolts. The flanges have threaded holes.
AFAIK apart from that they are identical.
Post Posted: Sun Jan 18, 2015 7:07 am
Here is NT flange
I'll try to find my NT pic.
Post Posted: Sun Jan 18, 2015 3:49 pm
? I Was pretty sure that Coil sierra flanges, whilst having the same bolt pattern as WT, are different in relation to seal and depth and won't work in a gear drive transfer.
Could be wrong, it's while since I've played with a coil sierra.
Post Posted: Sat Jan 24, 2015 7:43 am
You right Steve.
Coily flanges cant be fitted to the earlier cases.
Post Posted: Sat Jan 24, 2015 7:50 am
This is what I was wanting to know, Its all good however I have sourced some WT flanges. Thanks guys.
Users browsing this forum: No registered users and 50 guests
