It is currently Fri Jul 31, 2026 10:17 am
Vehicle: 1991 WT Tin Top
Post Posted: Thu Apr 17, 2014 4:15 pm
Hi guys,
I have a 91 Suzuki Sierra and just took it offroad, only to find I wasn't getting any drive to the front wheels.
I've done a quick search and all I could find was people saying it's probably a hub issue however, the front shaft was not spinning which makes me think it's to do with the transfer case.
Also the 4wd light on the dash has stopped working.
Are these issues linked? and is there an easy explanation that hopefully wont cost much?
Any info is much appreciated.
Cheers,
Linden
Post Posted: Thu Apr 17, 2014 4:22 pm
if the front shaft isnt moving its not from the hubs.
are you sure your engaging 4wd properly?
it would explain why the light isnt lighting
Vehicle: 99 grand vitara 2.0 auto
Post Posted: Thu Apr 17, 2014 4:29 pm
Is there no drive in both 4 lo and 4 hi?
Post Posted: Thu Apr 17, 2014 4:48 pm
Well when I bought the car it had reduction gears in it. So when I go into 4L i can definitely feel the difference in the gearing which makes me think that it is something to do with the transfer not putting power to the front.
I've had the car for a while now but last week was the first time offroad and early on when I had just bought it the 4wd light worked fine so I'm a bit confused.
Post Posted: Thu Apr 17, 2014 4:56 pm
so you shift into 4H
then from 4H into 4L and you can feel the reduction difference. cool.
i would say of the front shaft isnt turning some thing is wrong inside your transfer. it may have been assembled incorrectly when the gears were put in.
or worse some thing is broken.
you need to get some one to check it out.
Post Posted: Thu Apr 17, 2014 5:42 pm
Damn... as I thought.
Thanks for your help mate.
Users browsing this forum: No registered users and 110 guests
