| Disposable Gas bottle 2lt. http://auszookers.com/forum/viewtopic.php?f=37&t=46035 |
| Author: | tonyevans [ Tue Apr 29, 2014 1:47 pm ] |
| Post subject: | Disposable Gas bottle 2lt. |
OK - I have a welder that can be used for stick welding and/or TIG - Out where I live it is 75k to town to get a refill gas bottle and I would only use it now and then as I am used to stick and use that. I now have an LJ50 body to cut out rust and weld in panels and while I am OK with stick I an' that goos on paper thin metal they make LJ's out of My question is does anyone know how much welding you can do on light steel with a 2lt disposable bottle of gas? Cheers for any help |
| Author: | alexvitara [ Tue Apr 29, 2014 6:32 pm ] |
| Post subject: | Re: Disposable Gas bottle 2lt. |
Gas flow for tig is around 7 litres per minute. |
| Author: | want33s [ Fri May 02, 2014 3:20 pm ] |
NOT MUCH.... Tony how many cubic litres of gas are in the bottle? As above mig gas flow is 5-15 litres per minute, depending on the job. |
| Author: | tonyevans [ Sat May 03, 2014 8:05 am ] |
Thanks Jason - I thought that may be the case - I will have to keep fighting with the gas-less MIG I guess |
| Author: | Zook_Fan [ Sat May 03, 2014 8:48 am ] |
If you don't want to drive the 75k regularly why don't you get the biggest bottle you can so replacements are like once every two or three years? |
| Author: | tonyevans [ Sat May 03, 2014 9:08 am ] |
The rental out here is more than the gas |
| Author: | mnemonix [ Sat May 03, 2014 11:46 am ] |
Jump on ebay and look up seller "Atomic Gas Supplies" or "Speciality Gases" Buy your own cylinder, and swap & go when you need it exchanged from a range of speed e gas and core gas outlets, or via mail. D & E sizes available. You pay more for a refill than a BOC cylinder etc, but it costs you nothing if it sits in the shed unused for a couple of years until your next project. |
| Author: | tonyevans [ Sat May 03, 2014 3:36 pm ] |
Had a look and can not find them??????????? |
| Author: | SierraDan [ Tue May 06, 2014 4:53 pm ] |
alexvitara wrote: Gas flow for tig is around 7 litres per minute. I run 8-15 depending on the job/cup |
| Author: | want33s [ Tue May 06, 2014 7:07 pm ] |
tonyevans wrote: Had a look and can not find them??????????? Atomic website is under construction, all enquiries by email. Info@atomicgas.com.au Coregas Speciality gases. http://www.coregas.com/index.php?option ... Itemid=172 |
| Author: | tonyevans [ Thu May 08, 2014 3:29 pm ] |
Thanks Jason - I don't trust operations with websites like that |
| Author: | mnemonix [ Thu May 08, 2014 3:51 pm ] |
Definitely a valid business, it's been under construction for ~5 years at least. The owner of Atomic is a branch manager for one of the gas suppliers (speed-e gas I think). I've got 2 bottles through them and have had ~20 odd refills from them. I'll find the phone number in a few weeks when I'm back in NSW. |
