It is currently Mon Aug 03, 2026 4:10 am
Vehicle: 91 Vitara JX
Post Posted: Tue May 06, 2014 9:24 am
I'm going to assume this is a battery problem but I thought I would seek opinion from more educated folk here.
The wife's GV won't turn over the past few mornings sounds just like a dead battery but then starts fine later in the day once everything is warmer. Now obviously I assume its the battery just strange that it then starts later. Are there any other possibilities that could be causing said issue?
Vehicle: 99 Grand Vitara
Post Posted: Tue May 06, 2014 10:06 am
Grab a multimeter and check your battery voltage. Should be around 12v off then 13-14v while turned on. Gonna have a wild guess and say maybe your oil is too thick. What oil do you run in it? I was running 10W50 and when I went to 15W60, and as it started getting colder I noticed it would turn over a couple of times then start.
http://www.strictly4x4.com.au
Vehicle: Which one?
Post Posted: Tue May 06, 2014 10:37 am
I am running 10w50 in mine and on the last two days (first really cold sub-10 degree days since owning it) it has laboured ever so slightly when starting and even had a small amount of timing chain rattle for a few seconds upon starting.
Post Posted: Tue May 06, 2014 3:07 pm
I'm running 10w30, I run thicker in the SWB Vit and it starts fine... I was going to grab a new multi-meter tomorrow anyway
Vehicle: SJ80, SE416
Post Posted: Tue May 06, 2014 6:35 pm
It is not your oil. A battery's current output is dependent on temperature. If your battery is in marginal condition then it will cause slow or no cranking in cold weather. If you get a load test done it will probably show as stuffed.
If you pour boiling water over the battery on cold mornings it may warm it up enough to start.
Users browsing this forum: No registered users and 92 guests
