Joined: Tue Jun 09, 2009 11:30 pm Posts: 1009 Location: Sydney -ish
Vehicle: 92 Suzuki Sierra
Posted: Sat Aug 30, 2014 11:18 pm
thank you , i am aware of the coily fuel tank option. Suzuki tanks tend to have the fuel level meter and fuel pump as separate items in the fuel tank. It has come to my attention that other manufacturers make combo units.
As there are a ton of leafy owners (82-96!) trying to get their hands on coily tanks (96-98) i figured started thinking maybe other intank option might be feasible. If i knew the diameter of leafy it wuld save me time of dropping my own tak Surge tanks are an option but as stated in other threads they have their drawback in an offroad vehicle.
Posted: Sun Aug 31, 2014 11:03 pm
yeah after my last post i spent a lot of time trawling through ebay listings and comparing the images it became pretty obvious quick. i found a measurement for 5 point universal gauge sender gas at 40mm ID so its good to confirm the suzuki are same. Knowing that the most common in tank pump is ussualy a 38mm borsh kills the chances of a OEM combo unit with 40mm combo unit but i'm not ruling out the concept completely
A 38mm pump should still slip into a 40mm hole, and the unit would only need a single hose out as you could use the exsiting hoses for return etc (8mm?) and wires (another 5mm) At the very least you could have a pump without a gauge sensor and just rely on odometer (which is basically what i have ben doing for 10 years) I have some ideas about the level sensor but it not worth going into into the basic idea works and the pickup point is usable. i'm guessing baffles etc might come into play
Users browsing this forum: No registered users and 86 guests
