| 1997 Suzuki sj80 questions http://auszookers.com/forum/viewtopic.php?f=37&t=46482 |
| Author: | Onderbroek [ Sun Jun 01, 2014 5:35 pm ] |
| Post subject: | 1997 Suzuki sj80 questions |
Hi all Lots of noob questions coming up. I bought this Zook yesterday: Please confirm what model number it is, keep in mind that it is a South African Suzuki so its called a Samurai. What Model? What Engine? any workshop manuals? What oil to use for services? Where can i find the engine and chassis number? ![]() ![]() ![]() Thanks guys |
| Author: | atari4x4 [ Sun Jun 01, 2014 6:11 pm ] |
| Post subject: | Re: 1997 Suzuki sj80 questions |
wow a hightop coily, never seen one of those before, engine would be just the normal 1.3 g series engine. i use this as a guide for oils & capacity. http://www.datateck.com.au/lube/castr_au/default.asp i'm not a sierra person, but i think the chassis number would be on the rhs chassis rail in the right front wheel arch & the engine number will be on the LHS by the bellhousing below the dissy at the back of the motor. kind of strange that there are no compliance plates at all on the firewall. |
| Author: | Chop [ Sun Jun 01, 2014 7:12 pm ] |
Yeah wow a coily high top! Welcome |
| Author: | Onderbroek [ Sun Jun 01, 2014 8:32 pm ] |
Could not find the chassis number, think it might have been removed. Also couldnt find a sierra hi top anywhere on the net. By g series motor, is it the G13A? |
| Author: | Marko_SJ [ Sun Jun 01, 2014 9:51 pm ] |
Never knew there was a coily high top. Your engine will be a g13ba if it is original coily. Arent coily timing belts and some other small things different to ordinary leafy g13a / ba? other than that interchangeability is there. Edit: left to leafy* |
| Author: | greenzook89 [ Mon Jun 02, 2014 9:09 am ] |
Coily high top looks pretty much standard coily apart from that. Chassis number on mine is next to the fuel filler hose cover in the wheelarch on the chassis rail. |
| Author: | Onderbroek [ Wed Jun 04, 2014 2:27 pm ] |
I think the chassis plates have been removed - maybe i will discover them this weekend, will only be able to get some decent working time on it friday noght because of work |
| Author: | atari4x4 [ Wed Jun 04, 2014 2:42 pm ] |
it's a stamped number on the chassis rail, rather than a plate. there are plates that are usually on the firewall with the vin number etc & a heap of other details. the firewall compliance plates should look something like this, but be SJ80 specific. ![]() ![]() greenzook89 wrote: Chassis number on mine is next to the fuel filler hose cover in the wheelarch on the chassis rail. cheers, knew someone would know the exact location. |
| Author: | greenzook89 [ Wed Jun 04, 2014 4:30 pm ] |
Bear in mind because its South Africa it will have a different (or not at all) compliance plate. It should however have a build plate in the vicinity above the brake booster (which is obviously missing) |
| Author: | Onderbroek [ Thu Jun 05, 2014 4:48 am ] |
I suspect it might have been removed, will put it through registration this week. Hopefully all goes well |
| Author: | Dec [ Thu Jun 05, 2014 7:55 pm ] |
Great looking high top! More coilys:) You may want to look at disconnecting that positive terminal to your second battery before she shorts |
| Author: | Onderbroek [ Fri Jun 06, 2014 1:35 am ] |
will do - Anybody know how much oil the gearbox, transfercase, diffs and engine takes?
| Author: | greenzook89 [ Fri Jun 06, 2014 10:47 am ] |
I just refilled mine till the oil was level with the fill plug on the diffs. I think it was 1.2 litres each diff. Not sure about the gearbox and tcase sorry. |
| Author: | 1DYX [ Fri Jun 06, 2014 3:36 pm ] |
http://www.suzistore.com.au/help/suzuki ... ?kbartid=4 Engine Oil 4.0 L 20w50 Gearbox Oil 1.3 L 75w80 or VMX 80 Transfer Case Oil 0.8 L 75w80 or 80w90 Diff Oil Front 2.0 L 80w90 Rear 1.5 L 80w90 Cooling System 4.8 L Fuel Tank 40 L Radiator Cap Pressure 0.90kPA Thermostat Opening 82ºc Begin 95ºc Open Alternator Amp Rating 45A |
| Author: | Onderbroek [ Fri Jun 06, 2014 6:11 pm ] |
Thanks i ilso used that spec sheet to get most oils, Thing is i need to be sure, because i will be doing a service tonight and am leaving early tomorrow morning to go to a track, and i dont want to end up not having enough oil. Anybody have a airfilter part number? |
| Author: | Reubs [ Fri Jun 06, 2014 7:55 pm ] |
Onderbroek wrote: Thanks i ilso used that spec sheet to get most oils, Thing is i need to be sure, because i will be doing a service tonight and am leaving early tomorrow morning to go to a track, and i dont want to end up not having enough oil. Anybody have a airfilter part number? The above posted quantities sound corect to me. If in doubt most oil manufacturers have catalogues with this information. http://www.datateck.com.au/lube/castr_au/ If you buy 5L of engine oil, then 4L of gearbox oil and 4L of diff oil you can't go wrong. Air filter cross references to a A348. http://www.rycofilters.com.au/catalogue/part/make/SUZUKI/model/SIERRA/series/SJ413/part/A348 Google is your friend... |
| Author: | Onderbroek [ Sat Jun 07, 2014 6:28 am ] |
We don't have Ryco filters in South Africa. I used an sj413 filter Finished the service tomorrow will be her first trail
