It is currently Tue Aug 11, 2026 7:14 am
Post new topic Reply to topic  [ 47 posts ]  Go to page 1, 2  Next
Vehicle: 2000 Jimny
Post Posted: Wed Jun 11, 2014 12:01 pm
no doubt you guys are sick of seeing threads like this :roll:
so looking to lift the jimny, want to stick to 2" max to keep it simple.
looking at kits on ebay as there's not a lot of places around here to buy that type of thing.
what are peoples thoughts on a better quality 30mm-40mm lift, versus a cheap 50mm lift ?
here's the cheap 50mm kit for $500:
http://www.ebay.com.au/itm/2-50mm-Suspe ... 5898bae045
here's a 30-40mm kit for $599 that 'might' be better quality but i've got no idea:
http://www.ebay.com.au/itm/Suspension-L ... 5409bc7725
i'd probably rather not spend over $600, but if there's a really great kit for $700 i'd be willing to spend the extra money (but not if it's only a small improvement over a cheapy).
Post Posted: Wed Jun 11, 2014 12:22 pm
Well you're getting king springs either way, so the quality difference is just down to shocks.
Maybe do some research on king springs?
Steve
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Jun 11, 2014 2:36 pm
cheapest option, standard shocks and springs with 1.5"coil spacers
Post Posted: Wed Jun 11, 2014 2:54 pm
Kings with gabriels from super cheap?
Vehicle: 2000 Jimny
Post Posted: Wed Jun 11, 2014 3:17 pm
don't spose you know which springs/shocks i'd need to get (heights or even model numbers ?).
Post Posted: Wed Jun 11, 2014 4:57 pm
http://gabriel.com/product-search/light ... tnum=81147
thats for the shocks as for the springs im not too sure what the gun choice is on a jimny.
Vehicle: 2000 Jimny
Post Posted: Wed Jun 11, 2014 7:00 pm
Thanks for that but you need two lengths /types don't you? I've been googling about and can't find any info for springs or shocks. Have also sent off an email about the old man emu set up for a price
Post Posted: Wed Jun 11, 2014 7:06 pm
Yes my bad, That would be for the rears. I cant seem to find the numbers for the fronts.
FWIW i had king springs (40mm) on my Jimny, and the ride/flex was acceptable, and I am running Kings (again 40mm) on my coily but with Ultima shocks. For the price it does the job.
Vehicle: Sj51t
Post Posted: Wed Jun 11, 2014 7:33 pm
What shocks where you running in your jimny the ones you linked in the rear?
Post Posted: Wed Jun 11, 2014 8:01 pm
Yeah mate they were in it when I bought it already lifted. There are gabriels you can buy for the front that match the rears as I know some of the jimny blokes on here run them.
Vehicle: 2000 Jimny
Post Posted: Wed Jun 11, 2014 8:36 pm
if someone can let me know the serials for the gabriel shocks along with the right springs i could probably make a better set than is on ebay for less money. right now i'm looking at this set that's about $500;
king springs & some no name shock (ultra king i think):
http://www.ebay.com.au/itm/2-50mm-Suspe ... 0519505989
Vehicle: 2012 Jimny
Post Posted: Wed Jun 11, 2014 8:55 pm
Lots of Jimny's run kits from Jimnybits(http://www.jimnybits.co.uk), I think generally people are pretty happy with the JB 50mm kit. Might be a bit more than $500 but they are having a sale this weekend might get it cheaper. They ship to Aus as well and are good to deal with.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Jun 11, 2014 9:43 pm
^$650 shipped to oz.
Vehicle: 2000 Jimny
Post Posted: Thu Jun 12, 2014 9:00 am
you legend paul, i have that 2" pro comp lift in my cart along with a pro comp damper to price it up, came to about $AU830 delivered to aus since we don't have to pay their VAT (which makes it the exact same price as the shipping haha).
i'll be on jimny bits this weekend to see what they can do, stay tuned for a falling out with the missus though rofl.
Vehicle: 2012 Jimny
Post Posted: Thu Jun 12, 2014 9:09 am
Just maybe do a bit of research you have a arb bar and if you are getting a cage it might be that you will need the LHD diesel springs(a bit heavier duty) to support the weight. Maybe someone who has this kit with a heavy front bar will know more.
Vehicle: 2000 Jimny
Post Posted: Thu Jun 12, 2014 9:51 am
we're not allowed to fit cages in SA, but i could possibly fit a winch in future adding more weight to the front (which already has the arb bar).
will there be any issues going lhd diesel (being a rhd car) ? or will the springs just switch over no worries & just have the heavier spring rate you think ?
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu Jun 12, 2014 10:41 am
Pretty sure the LHD diesel fits fine, you just swap the springs so the tallest front is on the drivers side.
i dont have a problem with the es3000 shocks since i lets 10 extra psi out of my rear tyres.
dont bother pricing a steering damper. if you don't have abs, and have a LPSV get a position-er bracket but :)
Vehicle: 2000 Jimny
Post Posted: Thu Jun 12, 2014 10:48 am
what's LPSV & where can i get a positioner bracket from ? was thinking of grabbing one since they're tons cheaper on jimny bits than on local ebay etc.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu Jun 12, 2014 10:52 am
6 GBP extra from jimnybits
Jezza86 wrote:
by far the simplest, and easiest and cheapest mod ive done so far is correcting the load proportioning valve on the rear diff. the new bracket is 3" over standard, with holes for 1 and 2" as well.
would recommend pumping the breaks after installing it and going for a bit of a drive if you have installed new shoes after doing a lift. the shoes may not be fully adjusted due to the lower mass on them when they were fitted. the bracket makes a massive difrence, as i had almost no rear breaks before and now they are awesome.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu Jun 12, 2014 10:53 am
if you dont have a bracket and spring attached to the top of your rear diff dont worry bout it
Vehicle: 2000 Jimny
Post Posted: Thu Jun 12, 2014 11:06 am
i hadn't even given it a thought, had the valve on the gq & with the 2-3" lift it didn't really upset it at all so never added the bracket. will have to have a look under the jimny when i get a chance tonight (will be under there adjusting the clutch cable anyway).
Vehicle: 2000 Jimny
Post Posted: Thu Jun 12, 2014 3:08 pm
lol, now the ebay kit is on sale again at $480:
http://www.ebay.com.au/itm/2-50mm-Suspe ... 53fb5ea3a8
Vehicle: 2000 Jimny
Post Posted: Sun Jun 15, 2014 8:23 pm
so bit the bullet & decided to buy the pro comp set from jimny bits, along with a pro comp steering damper & brake balance bar. all came up saving over $100 so was pretty happy with that.
so went to buy it, first issue was 2% paypal surcharge, then followed by paypal grossly understating the conversion rate for au$ to uk pound. both things combined bumped the price up over $70 to what it 'should've' been & i ended up not bothering.
still got the option open for the ebay set for $480 delivered but also have a mate who has a workshop & said that EFS have always given him good deals. he thinks there's a good chance they'll know what springs/shocks i need so will check it out further. failing that i'll just buy the ebay set.
Vehicle: 2012 Jimny
Post Posted: Sun Jun 15, 2014 9:56 pm
When ordering from Jimnybits I just used visa as I found the same thing with paypal, they are arseholes with the exchange rates.
Vehicle: 2000 Jimny
Post Posted: Sun Jun 15, 2014 10:04 pm
i've gotten the codes for suitable king springs for a 50mm lift, KSFR-36H & KSRR-37H
any chance any one is able to find out the correct codes for those inexpensive gabriel shocks for me ?? i've googled everything i can think of & the gabriel site doesn't even have anything on jimnys.
Vehicle: 2000 Jimny
Post Posted: Sun Jun 15, 2014 10:05 pm
@ paul; last time i used a CC my bank slogged me a massive currency conversion fee. was pretty p!ssed about it.
Vehicle: 2012 Jimny
Post Posted: Sun Jun 15, 2014 10:15 pm
:roll: :lol: can't win sometimes
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Mon Jun 16, 2014 9:57 am
why the heck were you looking at a steering dampener? waste of money.
Would be handy if JB offered a AUD payment option but.
Vehicle: 2000 Jimny
Post Posted: Mon Jun 16, 2014 9:59 am
it worked out to something like $69 or $79 from jimny bits with the kit to fit. seemed like a good deal.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Mon Jun 16, 2014 10:58 am
yeh, it sounds great, but you don't need a steering dampener on a jimny, it covers up other issues that if you cant see they symptoms of can cost you a lot of money.
steering dampners are a waste of money.
i had one, a procomp jimny bits one. i run 30's and no power steering. if you put it back on my car i honestly couldn't tell you if it was on or not, it made no difference to my cars handeling apart from making bumpsteer more dangerous.
Users browsing this forum: No registered users and 40 guests
