| jimny brake lights not working http://auszookers.com/forum/viewtopic.php?f=37&t=46594 |
| Author: | GraphicX [ Wed Jun 11, 2014 6:50 pm ] |
| Post subject: | jimny brake lights not working |
Really happy with the car but my brake lights don't work. I've checked every fuse and the bulbs and all fine. Apart from the switch on the brake pedal, where else should I be looking? I've unclipped and recoupled the brake light switch, will test it for power tomorrow after work. |
| Author: | Chop [ Wed Jun 11, 2014 7:51 pm ] |
| Post subject: | Re: jimny brake lights not working |
It looks to have a tow bar? Maybe see if the plug wiring is any good or if they've scotched locked it and botched it? |
| Author: | Jezza86 [ Thu Jun 12, 2014 7:49 am ] |
+1 to towbar. scotch locks cut shit up. cables go through passengers side to take a look. |
| Author: | GraphicX [ Thu Jun 12, 2014 10:03 am ] |
thanks guys, will be fiddling with those connections tonight, might even back it up to a trailer & see if there's any lights to that as that'd rule the pedal switch out completely. |
| Author: | Jezza86 [ Thu Jun 12, 2014 10:35 am ] |
got a test light? might be easier then backing up to a trailer lol |
| Author: | GraphicX [ Thu Jun 12, 2014 10:46 am ] |
pantera has a gadget he's going to lend me that tells you if a wire is live etc so will borrow that & try. |
| Author: | atari4x4 [ Thu Jun 12, 2014 11:15 am ] |
just lick the wires, it's just like a 9v battery but only better. my guess is dodgy botchlocks that have sliced the original wires or corroded trailer plug, have you checked the fuse? |
| Author: | GraphicX [ Thu Jun 12, 2014 12:11 pm ] |
yeah checked all the fuses, the wires near the plug i'm guessing (& hoping) are a good chance as the car was being used to beach launch a dinghy & there's rusty bits everywhere (i'd say they either didn't rinse it thoroughly or even didn't bother every now & then). sucks that it's winter time to fiddle with the car as it's pretty much dark when heading home from work, literally have under an hour of light left to tackle this kinda thing. |
| Author: | GraphicX [ Sun Jun 15, 2014 9:55 am ] |
managed to fix the brake lights yesterday. checked out the trailer plug & that wasn't getting power either. in the end it was the actual switch on the pedal. called the local auto pro to see if they had any in stock but luckily they were closed so i pulled the switch apart & the mechanism was really simple & just needed a quick clean. |
| Author: | Jezza86 [ Sun Jun 15, 2014 11:45 am ] |
Awesome work. Good to know its serviceable too thanks! |
