It is currently Thu Aug 06, 2026 5:13 am
Vehicle: 1985 LWB sierra
Post Posted: Thu Jun 12, 2014 5:49 pm
Okay so I put Power Steering on my Sierra from a suzuki Vitara, first trip out it blew the high pressure hose, so I replaced the hoses $200 later :( the hose blew at the start of a 4wding day so I took the belt off and keeper driving. After reassembling it and turned the key it started posing out of the bottom of the box ( probably from running dry ) so I replaced it also and whilst at LCMP the same seal ( the one at the bottom of the steering box keeps dislodging itself and leaking :(, this wasn't the first time out with the new seal in. So why would it keep pushing the seal out? Thanks in advance.
Post Posted: Sat Jun 21, 2014 3:31 pm
Possible restriction in the return line?
Post Posted: Sat Jun 21, 2014 9:49 pm
Thanks ill try that, otherwise I'm going to attempt it rebuild it myself, are they hard to do? Also is the seal at the bottom meant to have the spring facing out?
Post Posted: Tue Jun 24, 2014 6:02 am
Spring goes to the inside.
Users browsing this forum: No registered users and 33 guests
