| Sierra running ruff - Carb issues? http://auszookers.com/forum/viewtopic.php?f=37&t=46683 |
Page 1 of 3 |
| Author: | Samwich [ Thu Jun 19, 2014 12:40 pm ] |
| Post subject: | Sierra running ruff - Carb issues? |
Hey guys, I am not very experienced at all when it comes to carby engines (other then replacing a geminis manifold to carb gasket) I have resantly purchased a Sierra with a 1.3l. and was wondering if anyone would like to help diagnosing the issue. Symptoms: - Wont start unless i spray carby cleaner down it - Idles for about 30secs - 2mins when started then dies - When pushing in throttle it dies (no power) Other info: - Pulled off fuel line, Turned car to start, fuel is clear + enough comes out (all looks fine) - When throttle is pumped (so it wont stall), as soon as the revs get high enough (maybe over 2k-2.5k by the sound) i can hold the throttle on fine without it dying. ---- I have no idea where to start, with the gemini carb, you can check the fuel level from the front of the carby. you can also undo the front of the glass to clean it out. Any info or suggestion would be awesome. Thanks Sam |
| Author: | bumstein [ Fri Jun 20, 2014 4:24 pm ] |
| Post subject: | Re: Sierra running ruff - Carb issues? |
Ok.. Lets see if I can get you a little direction. I'm no mechanic, so if anyone wants to chime and and correct me please feel free. It's either 1) a fuel issue 2) a spark issue Start a process of elimination. Pull the spark plugs out one by one, earth them out to the block/head and run the motor. Is there a spark in each one? Check compression while the plugs are out. Also with the motor idling, try pull the spark plug leads off one by one. Does the motor change? It will isolate if the problem is coming from a single cylinder or all of them. Have a look at the distributor cap, are the contacts and rotor button in good condition? If you've got a spare set of ignition leads, distributor cap or rotor button, try them out to see if theres a difference. If you've got a mate with a sierra that runs fine, borrow his/hers. Swap one at a time and see if theres a difference, if suddenly it springs to life with a particular part swapped thats likely your problem. Buy your mate a beer if he/she is of legal drinking age. I don't know how to test the vacuum advance off the top of my head, but I'm sure a quick google search would come up with a youtube vid on how to check this. If all the electrics are working well start looking for a fuel problem. Replace your fuel filter, it's cheap and can solve problems. I'd take the top off so I can see down the carby (but never look directly down while the engine is running or cranking, if it back fires you will set fire to your face or any other item thats in the way) If the engine starts working without the airfilter attached, perhaps it's being starved of air. Replace air filter, look for blockage. The jets could be blocked. Search for a little info on how to pull them out, give them a jolly good clean. It also occurs to me that there is a solenoid and piston setup that controls idle. I'm not sure how you'd go about testing it but I'm sure someone else could chime in on this one or search AZ and youtube. There was a thread somewhere here that had a little info on it but I can't find it just at the moment. Perhaps its a matter of taking it to a carby place and asking them to check over it. If it needs a carby kit, weigh up if you want to do it yourself (it can be pretty tricky and may not yield a great result IMO) or get a carby place to do it. Theres a few ebay carbys around or chase up one in the for sale/wanted sections that works. Some guys here will have a few laying around for various reasons, just make sure it works and is complete. Hope this gives you a place to start Sam, I'd love it give you heaps of guru tips on the matter but I'm not that guru'd myself.. Let us know what you come up with J |
| Author: | Samwich [ Mon Jun 23, 2014 12:20 pm ] |
Just ordered a rebuild kit for the carby, Does anyone know where i can find instructions on how to rebuild the kit? Thanks Sam |
| Author: | droverdave [ Mon Jun 23, 2014 1:47 pm ] |
The factory service manual. Pay particular attention to the float height setting. That is critical for proper operation. |
| Author: | Samwich [ Mon Jun 23, 2014 1:54 pm ] |
Where can i get a factory manual? just an auto shop? |
| Author: | zukmeista [ Mon Jun 23, 2014 2:53 pm ] |
Can download a manual from http://www.suzukiinfo.com
| Author: | Blkfxx [ Mon Jun 23, 2014 4:00 pm ] |
http://www.suzukiinfo.com/ |
| Author: | Samwich [ Mon Jun 23, 2014 4:34 pm ] |
I have a gregories manual. When removing the carb it says the manifold has "studs" in it... My carb has bolts that go through the top and screw into the manifold, does this mean I have a different type of carby to in the manual? |
| Author: | Samwich [ Mon Jun 23, 2014 4:36 pm ] |
Blkfxx wrote: http://www.suzukiinfo.com/ Seen this sight already, doesnt have a rebuild page |
| Author: | Blkfxx [ Mon Jun 23, 2014 5:02 pm ] |
Download the FSM from there. Should be all you need. |
| Author: | Marko_SJ [ Mon Jun 23, 2014 7:51 pm ] |
The FSM has information on specs and how the carby works..... I don't recall it having a a step by step "Disassembly / reassembly" though. Just read the manual, learn how it works and tear into it making note of the vac hoses and throttle linkages! Edit: spelling. |
| Author: | droverdave [ Tue Jun 24, 2014 6:53 am ] |
I have a holden drover factory workshop manual which does have a pretty good tear down of the carby. Mine is hard copy but i'm fairly sure its on that suzuki info website as well. |
| Author: | Samwich [ Tue Jun 24, 2014 8:38 am ] |
Found one, but my carby seems different? Will have to give it ago and hope for the best |
| Author: | Marko_SJ [ Tue Jun 24, 2014 12:19 pm ] |
Samwich wrote: Found one, but my carby seems different? Will have to give it ago and hope for the best Should be an "Aisan 3a" or something. It should be written on it. |
| Author: | Samwich [ Tue Jun 24, 2014 12:21 pm ] |
Will have a closer look tonight... What i dont understand is in the maual in the above link, it says you need a "tool" to check the float hight? is there another way to do this? Thanks Sam |
| Author: | Marko_SJ [ Tue Jun 24, 2014 12:44 pm ] |
You use pliers to bend the prongs, to adjust and measure the height with verniers or a drill of the same thickness. Well thats how I did mine. |
| Author: | Samwich [ Tue Jun 24, 2014 12:46 pm ] |
where do i measure between, and is it meant to be 7mm? |
| Author: | Marko_SJ [ Tue Jun 24, 2014 1:10 pm ] |
Had to double check the FSM to make sure the way I did it ages ago was right. Its on page 129 FSM, float height is 7mm, and its not from the portion that pokes out from the rest, just sit it down upside down as shown and go from the body of the float. |
| Author: | Marko_SJ [ Tue Jun 24, 2014 1:20 pm ] |
Oh and drover dave was right. It does have information on assembly and disassembly. |
| Author: | Santos [ Tue Jun 24, 2014 1:23 pm ] |
Most SJ413 manuals floating around the web have the hitachi carb, so that would probably be the explaination for studs. Like its been suggested earlier download the holden drover manual. In a nut shell. - You have 4 long bolts to remove the carby from the intake plus any sensor wires and vacuum hoses - 5 phillip screws to remove the 'lid' and have access to the float etc. remove the top right way up as you dont want the components to drp out like acc spring, float retainer pin etc. - To separate the throttle body lower from the upper carb body you have 4 bolts . 2 external bolts (8mm head) and 2 internal that you can see in the two smaller holes in the middle on either side of the primary/secondaries. (flathead screwdriver) - Soak all the parts in general purpose thinner for 24hrs or so. Drain well and blow compressed air through all the orifices. Reassemble. - Do not forget to buy new vaccum hose and replace all the connection. Do not reuse your old tubes. If it doesn't work, you can send me the carburetor i can send you back a virtually new simplified carburetor with manual choke, new everything. springs, jets, clips, foam float, vaccumm actuator, venturi's etc for $350 incl return post. Two week turn around upon receipt of old carb. |
| Author: | Samwich [ Tue Jun 24, 2014 5:03 pm ] |
Thats alot santos. Question.. the two flat head screw driver screws where are they? Are the in the float chamber? |
| Author: | Santos [ Tue Jun 24, 2014 6:34 pm ] |
Samwich wrote: Thats alot santos. Question.. the two flat head screw driver screws where are they? Are the in the float chamber? nope, flip the carb upside down (after removing springs etc from inside carb or put the 5 philip screw 'lid' back on) You should see a total of 8 holes. 2 big ones are your Primary and secondary throttle body. the 4 outer ones is where the 4 long bolts pass through to the intake, the two ones in the middle have flathead screwdriver BOLTS. It's a bit deceiving as one of the bolt has a hollow hole through it (float side when it comes time to putting it back together) Need to dig out my hard copy of the holden drover manual to see how different the instructions are, i've always looked in my suzuki manual which is no help as the carb section is different to the digital USA version. |
| Author: | Samwich [ Tue Jun 24, 2014 6:52 pm ] |
Cheers man.. I have no idea how I missed those :/ Also.. when I took the top part off, a little ball baring + another piece the same size as if fell out from somewhere... any idea? |
| Author: | Samwich [ Tue Jun 24, 2014 7:10 pm ] |
Also, do these parts go into each other in this order?
| Author: | Samwich [ Tue Jun 24, 2014 7:35 pm ] |
What spring??? :S |
| Author: | Santos [ Tue Jun 24, 2014 7:45 pm ] |
ha marko beat me to it. That little o-ring might be for the Dont forget to clean out the crud that build up between the fuel line entry and the needle seat. Should just be a 14mm head bolt. it has two washers to stop it leaking.. |
| Author: | Marko_SJ [ Tue Jun 24, 2014 7:49 pm ] |
Samwich wrote: What spring??? :S #50 below. The accelerator pump check spring. Not my pic.
| Page 1 of 3 | All times are UTC + 9:30 hours |
