It is currently Fri Aug 07, 2026 10:27 am
Vehicle: 91 sierra wt
Post Posted: Sun May 18, 2014 9:23 am
hey guys i replaced my snapped speedo cable a few weeks ago and i don't think its sitting properly in the transfer. i had my first drive of it yesterday no speedo until i just about got home and it worked for about 5 seconds. i removed the cable and tried turning it with it a screwdriver the wife said it was slightly moving?? is there something i'm missing is there a trick or something? any help or ideas greatly appreciated
cheers guys pat
Vehicle: 93maruti
Post Posted: Mon May 19, 2014 7:23 pm
Step 1: make sure cable is all the way home at BOTH ends. If this fails
Step 2 : pull off bottom end and put cordless dril on it.....speedo reads high, success box end is the failure.if not
Step 3: pull off speedo end, if you can't spin it speedo is the failure.
You'll probably find when you get both ends seated properly the problem will be gone
Post Posted: Tue May 20, 2014 6:43 am
Righto I will try that one this afternoon thanks buddy :)
Vehicle: 1994 suzuki sierra swb wt
Post Posted: Tue Jul 01, 2014 3:46 pm
Hey guys just wondering if you have to take the dash claster apart to replace the cable
Vehicle: Drover pickup turk
Post Posted: Tue Jul 01, 2014 6:21 pm
You don't have to take the cluster apart but you do have to pull the cluster out of the dash.
I like the tuna here
Post Posted: Fri Jul 11, 2014 6:13 pm
Yea I removed the cluster to swap it over, apparently you don't really need to but I found it easier, I think it would be easier to drop the steering column as I broke the clips on my trying to remove it! Good luck
Users browsing this forum: No registered users and 42 guests
