It is currently Fri Aug 07, 2026 4:27 pm
Vehicle: 1992 suzuki vitara
Post Posted: Tue Jul 15, 2014 5:11 am
Changed the diff oil in my vitara with this brand oil Image
Went we'll drained the old stuff and filled it up till it came out the filler hole.. Took it for a test drive felt better than ever now I went to take off this morning and it feels like the handbreak is dragging could it be the oil? And yes I did fill it up and handbreak was fully off and yes I was in first gear thanks
Cheers Joel!!
Post Posted: Tue Jul 15, 2014 6:00 am
I can't find the grade on that label, is there something on the back? It's probably a bit thick for what you need
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Tue Jul 15, 2014 6:09 am
Cold morning? Do you have a lsd?
90 is thicker then 80w-90,
Needs more heat to lower the viscosity.
Post Posted: Tue Jul 15, 2014 6:14 am
Oh ok the book said lp5 or what ever it says might try taking it for a drive this afternoon sd defiantly get some thinner oil.
Jezze it seems to twin up when I do gravel Hackies put in not sure how do I tell ? Thanks
Cheers Joel!!
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
4 Litre
LS 90
Hypoid gear oil to be used in heavily charged transmissions for cars.
Contains LS (Limited Slip) additives
API GL-5-LS
Mil-L-2105D
ZF TE-ML 05C/12C/21C
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Tue Jul 15, 2014 6:17 am
http://m.supercheapauto.com.au/Product/ ... From=60202
4 Litre
80W-90
Lubrication of heavily charged gear transmissions that require special anti-wear protection
API GL-5
Mil-L-2105D
ZF TE-ML-05A/07A/16B/17B/19B
Ford M2C9002-A
MAN 342 Type M
Mack GO-G
GM
Post Posted: Tue Jul 15, 2014 6:18 am
Pretty cold. I'm not sure about the LSD twins up sometimes when I was doing some drifts on the gravel but in not sure. I'll try some 80w-90 gear oil
Cheers Joel!!
Post Posted: Tue Jul 15, 2014 6:19 am
Jezza86 wrote:
4 Litre
LS 90
API GL-5-LS
Mil-L-2105D
So both of them would be alright or the second one ?
Cheers Joel!!
Post Posted: Tue Jul 15, 2014 6:24 am
Jezza86 wrote:
http://m.supercheapauto.com.au/Product/Chief-Tanoa-Gear-Oil-80W-90-4-Litre/344508?menuFrom=60202
4 Litre
80W-90
API GL-5
Mil-L-2105D
Ford M2C9002-A
MAN 342 Type M
Mack GO-G
GM
Thanks mate I really appreciate it. I'll give the second one a go. I thought the oil might be to thick took ages to get I'm there with the pump thing
Cheers Joel!!
Post Posted: Tue Jul 15, 2014 8:33 am
The 80W/90 grade oil is better suited
Users browsing this forum: No registered users and 40 guests
