http://auszookers.com/forum/
Jimny UHF Radio Install
http://auszookers.com/forum/viewtopic.php?f=37&t=47181
Author:  Rob` [ Mon Jul 28, 2014 10:18 am ]
Post subject:  Jimny UHF Radio Install
Hi all,
I've been searching through the forums for installs people have done for their CB radio. I've got a Uniden UH-7740NB UHF Radio (http://www.uniden.com.au/australia/p_uh7740nb_index.asp), but at the moment I've only got it velcro'd to the carpet on the transmission tunnel (because I'm a pro at this).
I'm looking for a more permanent and prettier solution, so does anyone have any photos of installs of UHF radio installs underneath the ash tray, or another place where I won't have to cut up the dash or similar.
As always, any help / guidance is appreciated.
Author:  pete_79 [ Mon Jul 28, 2014 11:53 am ]
Post subject:  Re: Jimny UHF Radio Install
I mounted my GME in the ashtray slot, but it looks like your Uniden is about 20mm wider and a few mm higher then my unit so might not fit.
Here's mine for reference anyway.
I flattened the sides of the metal ashtray slide and drilled 2 holes for the screws on the side of the unit.
Author:  Jezza86 [ Mon Jul 28, 2014 12:11 pm ]
http://www.uniden.com.au/RESOURCES_MAIN ... 0NB_OM.pdf
page 10
DIN-E Sleeve, DIN-E rubber
ring and keys for vehicle
installation
(UH7750NB only)
put it in the dash and get a single din head unit.
Author:  ozzycouch [ Mon Jul 28, 2014 12:27 pm ]
Mine ended up on the roof (Vitara) with an extension running the mic in to the glove box.
Author:  Rob` [ Tue Jul 29, 2014 7:04 am ]
I had a look under the dash last night where I wanted to put it, I think it should be ok if I make up some type of bracket... I'll keep having a dig around and if I find anything I'll report back haha
Author:  Bugsta [ Fri Aug 01, 2014 9:41 pm ]
Jezza86 wrote:
http://www.uniden.com.au/RESOURCES_MAIN/pdfs/UH7740NB_UH7750NB_OM.pdf
page 10
installation
(UH7750NB only)
Hey what brand is that head unit? I'm looking for a screen that can display more than just a couple of lines. Don't want CD but would like Bluetooth phone connection.
Author:  Jezza86 [ Sat Aug 02, 2014 7:49 am ]
45 bucks from china. 4x65w outputs
Never had a problem in 3 years.
No brand name
Author:  Bugsta [ Sun Aug 03, 2014 10:46 pm ]
As in eBay?
Author:  Jezza86 [ Sun Aug 03, 2014 10:48 pm ]
Aliexpress but sure you could find one on ebay
