It is currently Sat Aug 08, 2026 10:04 pm
Post Posted: Sun Aug 03, 2014 8:51 pm
Just need to check if I have this right. Checking if I have the distributor and rotor set up correctly. With the two camshafts and the crank all at their correct locations for installing a timing belt, as per the attached diagram, is this the firing position for the No. 1 cylinder? (IE with the rotor button pointing at the terminal for No.1.) Thanks! :)
Post Posted: Sun Aug 03, 2014 10:28 pm
Yes. IIRC cylinder #1 is the closest to the firewall
Post Posted: Tue Aug 05, 2014 4:29 pm
Thanks for that. I think that No 1 is usually the one closest to the timing gear. One and 4 are both at TDC at the moment, hopefully with the correct one at the top of the compression stroke!
Found it
Users browsing this forum: No registered users and 72 guests
