Page 1 of 1
[ 6 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
jimmey
Joined: Thu Dec 01, 2011 1:42 am Posts: 108 Location: Ormeau, SE QLD
Vehicle: 89 SWB Sierra (soft top)
 Posted: Tue Sep 23, 2014 2:03 pm |
Hey Guys,
Just wondering if someone could give me a quick run down on the math behind working out revs from gear ratios and tyre sizes and what not?
For example I want to put an M15A (non VVT) motor with an M13A manual box and tranny running standard sierra diffs, pushin 30/31 inch tyres. (In a 90ish model Wt Sierra)
so to my understanding it goes
M13A Ratios
1st 4.425 2nd 2.304 3rd 1.674 4th 1.190 5th 1.000 Reverse 5.151 Final gear ratio 3.416
Transfer gear ratio High 1.320 Low 2.643
G13A Ratios
1st 3.652 2nd 1.947 3rd 1.423 4th 1.000 5th 0.864 Reverse 3.466 Final gear ratio 3.727
Transfer gear ratio High 1.409 Low 2.268
Question 1: This is really more of a "correct me if I'm wrong", but since the diff ratio is only out by roughly 0.500 on the M13A, everything should really be running in check through the whole drive line? like the M15A would be runnign at the correct revs (with stock tyres)?
Question 2: Would the revs be higher or lower since the diff ratio is out by 0.005?
Questions 3: How the hell do I work out all of this and then work out tyre sizes and what not?????
Cheers Guys!
Jimmy
Marko_SJ
Joined: Tue Jan 17, 2012 1:40 am Posts: 2979 Location: Darwin, NT
Vehicle: WT sierra, GU CRD
 Posted: Tue Sep 23, 2014 2:36 pm |
Jimmy, do any of these calculators help? http://www.rocky-road.com/calculator.htmlOn 30 inch tires, in 5th gear m13a box (1:1), Edit: I see you mean sierra transfer (1.4) ( and sierra WT diffs (3.7) I get 3480rpm at 60mph which is a bees dick near 100kmh. This seems close to where my stock sierra (although spinning faster I think) was at 100 with 30s and no gearing IIRC. Apologies if this is not what you were looking for.
_________________ I love ZD30. :)
madmacca
Joined: Fri May 14, 2010 8:46 am Posts: 928 Location: Lesmurdie W.A.
Vehicle: X-90 + Lwb Sierra + DeVitt +++
 Posted: Tue Sep 23, 2014 4:11 pm |
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13008 Location: Melbourne
 Posted: Tue Sep 23, 2014 6:10 pm |
Do you have excel? Build your own - it's about 10 minutes work.
I use mine all the time.
jimmey
 Posted: Tue Sep 23, 2014 6:58 pm |
Marko_SJ wrote: Jimmy, do any of these calculators help? http://www.rocky-road.com/calculator.htmlOn 30 inch tires, in 5th gear m13a box (1:1), Edit: I see you mean sierra transfer (1.4) ( and sierra WT diffs (3.7) I get 3480rpm at 60mph which is a bees dick near 100kmh. This seems close to where my stock sierra (although spinning faster I think) was at 100 with 30s and no gearing IIRC. Apologies if this is not what you were looking for. Thanks so much!! this calculator works amazing!!
Marko_SJ
 Posted: Wed Sep 24, 2014 3:49 pm |
jimmey wrote: Marko_SJ wrote: Jimmy, do any of these calculators help? http://www.rocky-road.com/calculator.htmlOn 30 inch tires, in 5th gear m13a box (1:1), Edit: I see you mean sierra transfer (1.4) ( and sierra WT diffs (3.7) I get 3480rpm at 60mph which is a bees dick near 100kmh. This seems close to where my stock sierra (although spinning faster I think) was at 100 with 30s and no gearing IIRC. Apologies if this is not what you were looking for. Thanks so much!! this calculator works amazing!! Glad to help the few times I can...
Page 1 of 1
[ 6 posts ] |
Users browsing this forum: No registered users and 92 guests
