It is currently Tue Aug 11, 2026 5:36 pm
Vehicle: 1984 holden drover (lwb zook)
Post Posted: Sun Sep 28, 2014 2:45 pm
Right'o about a week ago some wanker smashed my right hand side drivers window and i got quoted 300 from a glass shop for a new one or 150 i can order and put it in my self
Is it easy to put in? And is it really time consuming? I have all the trim and shit out the door just looking at if its worth the 300 or just 150 and some trouble ( its on a serra lwb )
Also is there is a thread on how to do it a link would be great
Thanks in advance
Sam
Ps im dislecsic and shit at english my apologise
Vehicle: Drover pickup turk
Post Posted: Sun Sep 28, 2014 2:51 pm
Pretty simple job, 2 screws separate the window from the reg and then it's just a matter of pulling it out from the top. The inverse to reinstall the new one.
$300/150 is pretty steep for a side window, You sure they weren't quoting a windscreen?
I like the tuna here
Vehicle: LWB Sierra & XL7
Post Posted: Sun Sep 28, 2014 3:10 pm
Very easy to do and you can get a replacement from a wrecker for about $20.
When you see how the window regulator works and where it's bolted you will be like.. ahhh is that it.
There's 2 bolts that hold the glass rail in place. If you get a 2nd hand part it's just a matter of remove and replace, you won't have to replace the rail.
The only other tip is, use a vacuum to suck up all the glass inside the door, otherwise the rattling will drive you bonkers.
'92 Vitara & Camper trailer
Post Posted: Sun Sep 28, 2014 5:24 pm
Hey guys i saw those two screws and cant seem to get them out any tips?
Also i have cleaned out all the old glass and there are no wreckers near me with a sierra
150 is from suzi store
Post Posted: Sun Sep 28, 2014 6:13 pm
They could be rusted up, I loosened mine with vice grips and replaced them with hex heads.
Post Posted: Mon Sep 29, 2014 12:44 pm
Mine are philips heads
Post Posted: Mon Sep 29, 2014 12:51 pm
As were mine.
Post Posted: Mon Sep 29, 2014 8:06 pm
So how did you loosen them with vice grips?
Post Posted: Mon Sep 29, 2014 8:13 pm
clamp onto the screw head with the pliers part, lock it on & turn anticlockwise? :?
Post Posted: Wed Oct 01, 2014 5:31 pm
Isn't there a thread on how to undo all those stupid Suzuki Phillips head screws?
Post Posted: Wed Oct 01, 2014 6:21 pm
yess!! you made it
Post Posted: Sat Oct 04, 2014 7:05 pm
If you are in Brisbane I have a window you can have
Post Posted: Sun Oct 05, 2014 12:26 am
All good got one of a mate for 50$
Post Posted: Sun Oct 05, 2014 2:53 pm
WD40 has a new product that is MUCH better than PB Blaster or any of those so-called rust penetrants.
Here is the link in the States (I hope it is available in Australia):
http://www.wd40specialist.com/
This stuff is GREAT! I used it to remove the badly-rusted philips screws on the rear door interior access panel on an SJ413 hardtop.
Spray it on and let it set for a couple of hours. Screws come right off!
The only other method I have had success with on Suzuki Philips-head screws involves wire-welding a nut onto the face of the screw - probably not practical in this situation... :lol:
-Ack
http://www.acksfaq.com
88, 88.5 SJ413
Users browsing this forum: No registered users and 104 guests
