It is currently Thu Aug 13, 2026 5:56 pm
Vehicle: Vitara/LWB "ZOOKINI"
Post Posted: Sun Nov 09, 2014 7:03 pm
Evening fellow enthusiasts,
Quick question, do transfer cases have a synchro gear? Mine used to be able to shift on the fly. Now I must stop to get it in, coming out whilst moving is easy and smooth.
Not sure if this would be worth fixing?
Vitara= Awesome
Post Posted: Tue Nov 11, 2014 9:00 am
Vitara = no synchro, Grand Vitara = synchro
Vehicle: SJ80, SE416
Post Posted: Tue Nov 11, 2014 2:05 pm
You should be able to shift from 2hi to 4hi without stopping so long as the freewheel hubs are locked.
If your tyres are different sizes, your hubs are seized, or some part of the drivetrain is broken such that the front shaft and rear shaft aren't rotating at the same speed then you won't be able to shift. You shouldn't change 4hi to 4lo on the fly, there is no synchromesh.
Are both hubs engaging? That would be the first thing I'd check.
Post Posted: Wed Nov 12, 2014 5:36 pm
Just rebuilt the hubs. Ill jack it up and have a look. Thanks for the advice!
Vitara= Awesome
Users browsing this forum: No registered users and 56 guests
