It is currently Tue Aug 11, 2026 8:43 pm
Vehicle: 1984 holden drover (lwb zook)
Post Posted: Wed Oct 08, 2014 2:26 pm
is there any how to threads on diff pushes or moving the diff forward if so please may you link me as i cant seem to find them if there is any.
planning on moving it about 50 mm
Post Posted: Wed Oct 08, 2014 2:52 pm
1" forward on a leafy is easy, but may slightly bind on the pitman.
More than 1" becomes a lot harder.
Just drill the holes in perches and spring backing plates (4 holes).
you may desire a drive shaft extension (for more spline engagement), and keep an eye on brake lines depending on lift.
Post Posted: Wed Oct 08, 2014 2:56 pm
Oh
Pay attention to the holes and orientation etc
Pretty sure someone on here proudly got it all together, before realising they pulled the diff back an inch, because had wrong side of perch drilled.
Post Posted: Wed Oct 08, 2014 3:38 pm
or search for "stealth ruf" if you wish to do rears up front?
Post Posted: Wed Oct 08, 2014 6:04 pm
i have no access to welding equipment or anyone willing atari4x4 so i cannot
and so literally just put another 4 holes in the perches but an inch forward? wouldnt this make the perch weak?
Vehicle: Drover pickup turk
Post Posted: Wed Oct 08, 2014 7:08 pm
Only have to do 4 holes total, 2 per side.1 in the spring perch and 1 in the spring plate all the same distance from the original hole
I like the tuna here
Post Posted: Wed Oct 08, 2014 10:11 pm
Ohhh okay have you done it on my twin? ;)
Post Posted: Wed Oct 08, 2014 10:43 pm
Payes to be careful of the shock as well. I needed to space my lower shock mount back as the shock hit the bumpstop. Oh and
my diff also missed the bumpstop so I had to space it forward as well.
My diff was about 50mm forward
Post Posted: Wed Oct 08, 2014 10:50 pm
Haha
I had to move mine backwards after RUF and before P/S but the same idea applies.
I'll see if I have any pics.
Users browsing this forum: No registered users and 54 guests
