| diff push/move forward (is there a thread?) http://auszookers.com/forum/viewtopic.php?f=37&t=48041 |
| Author: | bibby [ Wed Oct 08, 2014 2:26 pm ] |
| Post subject: | diff push/move forward (is there a thread?) |
is there any how to threads on diff pushes or moving the diff forward if so please may you link me as i cant seem to find them if there is any. planning on moving it about 50 mm |
| Author: | jdk81 [ Wed Oct 08, 2014 2:52 pm ] |
| Post subject: | Re: diff push/move forward (is there a thread?) |
1" forward on a leafy is easy, but may slightly bind on the pitman. More than 1" becomes a lot harder. Just drill the holes in perches and spring backing plates (4 holes). you may desire a drive shaft extension (for more spline engagement), and keep an eye on brake lines depending on lift. |
| Author: | jdk81 [ Wed Oct 08, 2014 2:56 pm ] |
Oh Pay attention to the holes and orientation etc Pretty sure someone on here proudly got it all together, before realising they pulled the diff back an inch, because had wrong side of perch drilled. |
| Author: | atari4x4 [ Wed Oct 08, 2014 3:38 pm ] |
or search for "stealth ruf" if you wish to do rears up front? |
| Author: | bibby [ Wed Oct 08, 2014 6:04 pm ] |
i have no access to welding equipment or anyone willing atari4x4 so i cannot and so literally just put another 4 holes in the perches but an inch forward? wouldnt this make the perch weak? |
| Author: | Blkfxx [ Wed Oct 08, 2014 7:08 pm ] |
Only have to do 4 holes total, 2 per side.1 in the spring perch and 1 in the spring plate all the same distance from the original hole |
| Author: | bibby [ Wed Oct 08, 2014 10:11 pm ] |
Ohhh okay have you done it on my twin? |
| Author: | shep [ Wed Oct 08, 2014 10:43 pm ] |
Payes to be careful of the shock as well. I needed to space my lower shock mount back as the shock hit the bumpstop. Oh and my diff also missed the bumpstop so I had to space it forward as well. My diff was about 50mm forward |
| Author: | Blkfxx [ Wed Oct 08, 2014 10:50 pm ] |
bibby wrote: Ohhh okay have you done it on my twin? Haha I had to move mine backwards after RUF and before P/S but the same idea applies. I'll see if I have any pics. |
