It is currently Wed Aug 12, 2026 6:37 pm
Vehicle: 1984 holden drover (lwb zook)
Post Posted: Fri Oct 17, 2014 1:30 pm
hey guys i just am wanting to buy a NT diff center which is 3.9 gearing but the person dosent know if its a NT or WT center is there anywhere on the crown gear or something where you can work it out?
Vehicle: Sierra
Post Posted: Fri Oct 17, 2014 2:48 pm
Count the teeth on the crown wheel and divide them by the number of teeth on the pinion
Post Posted: Fri Oct 17, 2014 3:01 pm
There in the housing its kinda hard to count
Post Posted: Fri Oct 17, 2014 3:11 pm
Check the circle spin ratio...
Post Posted: Fri Oct 17, 2014 3:39 pm
How? Or where??
Vehicle: 92 wt soft top sierra
Post Posted: Fri Oct 17, 2014 6:12 pm
Ratio is 3.9:1
Jack the car up mark the tyre and the tail shaft spin tail shaft about 3.9 times so roughly 4 tyre should of made 1 revolution not accurate but thats the only other way with taking it out
Post Posted: Fri Oct 17, 2014 11:40 pm
It is out though
Post Posted: Fri Oct 17, 2014 11:47 pm
is the diff centre out of the housing, if so count the teeth as discribed.... if the diffs are complete but not fitted to the car, do what killa zook said & measure the circle spin ratio by turning the tailshaft & seeing how far the axle turns.
Post Posted: Sat Oct 18, 2014 12:10 am
The center is out but the pinion is behind all the crown gears and stuff its okay mine are nt and the ones i bought are wt
Post Posted: Sat Oct 18, 2014 12:33 am
WTF, i was confused before, now i'm confuddled. :? :lol:
count the teeth on the crown wheel... put a paint mark on the 1st one & start counting, same goes with the pinion.
the pinion gear is the star shaped one below where the hose connects to the top. (it's a vacuum operated GV front diff so ignore the crap)
Post Posted: Mon Oct 20, 2014 1:04 am
OR - mark the crown wheel and rotate the input flange - how many revolutions of the input for one revolution of the crown wheel?
Vehicle: 85 Suzuki Sierra
Post Posted: Tue Oct 21, 2014 10:58 pm
NT difs have 8mm holes in the flange and WT difs have 10mm holes in the flange MOST of the time (I have heard there is some odd models or people could have swapped flanges). That's how I tell them apart in my spares collection ;).
Orange LWB Sierra
Users browsing this forum: Google [Bot] and 53 guests
