It is currently Thu Aug 13, 2026 9:45 am
Vehicle: 2000 Jimny
Post Posted: Sun Nov 09, 2014 9:22 am
i've done a search & posted asking but can someone please take a look at this & tell me if this is the correct engine to convert my G13BB jimny to a 1.6:
i've messaged the seller & asked if it has the green injectors, he also lists it as a 1.5 litre, but i'm guessing this is an error, or are there 1.5 litre engines out there ?
also, what is the story with the starter motor, i've read about needing a particular starter motor but i can't find any definitive info. would like to work all this out before buying. thanks.
Post Posted: Sun Nov 09, 2014 10:26 am
Suzuki did use a G15 engine in some JDM Balenos (Cultus Crescent) so it could be a 1.5.
Vehicle: 2000 Jimny
Post Posted: Sun Nov 09, 2014 10:49 am
argh, i hope not, it's $450, 95,000ks & has warranty. seems like a good buy if it's the correct engine.
Vehicle: 92 wt soft top sierra
Post Posted: Sun Nov 09, 2014 11:54 am
Have a look at the engine serial number should be stamped on the block g16b
Vehicle: 2000 Jimny
Post Posted: Sun Nov 09, 2014 4:35 pm
just received a reply from him, sounds like fordem might be on the money that it's a JDM 1.5ltr & not the G16BB. he has 2 other balenos that are aussie variants so have asked about them. wait & see what he says but this particular engine had my interest as the kilometres were quite low & so was the price.
Post Posted: Sun Nov 09, 2014 6:48 pm
1.5 can't be that much different can it?
Injectors are easy to change.
Bell housing will be 1.3 or 1.6 (I'd bet 1.6) likewise the exhaust side of the head.
Post Posted: Sun Nov 09, 2014 7:10 pm
IIRC the G15 has the same bore as the G16 but just has ~5mm shorter stroke. Should be a tad more rev happy than the 16
Vehicle: 2000 Jimny
Post Posted: Mon Nov 10, 2014 9:12 am
one thing i'm keen on with the G16BB is that its peak power is only around 4,000rpm which i think would probably be better for off roading.
Users browsing this forum: No registered users and 42 guests
