Joined: Thu Oct 23, 2014 2:14 pm Posts: 87 Location: Calamvale
Vehicle: Sierra
Posted: Fri Nov 07, 2014 9:32 pm
Having a few issues with stalling once the car is hot as soon as you put the clutch in so thought I would start by replacing all the vacuum lines and cleaning the fuel cut off solenoid. When I pulled the solenoid out the o-ring was missing, had a bit of a fish around up the port it came out of in case it came off when I removed it but didn't manage to find the o-ring so I figured it wasn't there to start with. Put it back in wired it up and hit the key and it ran and idled fine.
What happens if the o-ring is not replaced? I don't want to come out and find a big puddle of fuel under the car in the morning. Could this be the problem I had with stalling when it got hot.
I should mention the stalling only happened after restarting from a 10 minute stop for my son to show his mates the new car, Previously I had driven about 40kms with no issues stopping and accelerating away from lights etc
Appreciate any help........................anyone interested in rebuilding the carb for me for a few bucks?
If you're referring to the solenoid near the top of the carb throat (I know it as the anti-dieseling solenoid) - I don't recall any O-rings - all it does is block an air passage in the carb so there will be no fuel leakage, and that was probably not the cause of the engine stalling - if it was, it would have stalled as soon as you took your foot off the gas.
Joined: Wed May 05, 2010 11:50 am Posts: 823 Location: Beenleigh
Vehicle: Coil Sierra
Posted: Tue Nov 11, 2014 8:35 pm
A new o ring comes in a carby kit. But the shop that installed the kit lost both of mine. I bought a o ring kit from supercheap and used that. When i had carby problems i removed this fuel cut off switch and put a bolt in there. Over runs now and again but not every time.
Vehicle: Sierra
Posted: Thu Nov 13, 2014 8:59 pm
Excuse my ignorance but what doe it over run mean? Is it safe to run the thing without the fuel cutoff solenoid?
Users browsing this forum: No registered users and 36 guests
