It is currently Thu Aug 13, 2026 2:56 pm
Vehicle: 1984 holden drover (lwb zook)
Post Posted: Mon Nov 10, 2014 5:17 pm
does taking out your load spring really give you much more flex or is it not worth it?
or if there's any other ways to get more flex out ya spring pack?
Regards
Sam
Post Posted: Tue Nov 11, 2014 7:57 am
Taking the load leaf out will make it lower and softer. It won't necessarily provide "more flex" as it depends on the weight on the spring whether you can get the full compression out of it.
The only sure fire way to get more flex from a leaf pack is to use a longer set of springs, which comes with its own set of issues.
Post Posted: Tue Nov 11, 2014 9:33 am
yes alien i will be doing ruf about next week with shock hoops and rear shock bar im just wondering because if its worth it ill take out the load springs in the new front ones and the existing rear ones, you feel?
Post Posted: Tue Nov 11, 2014 4:05 pm
That would depend on the stiffness of the new springs though, which you won't know till you fit them.
