Joined: Sun Jan 29, 2012 9:34 pm Posts: 131 Location: Melbourne
Vehicle: Vitara/LWB "ZOOKINI"
Posted: Sun Nov 09, 2014 7:03 pm
Evening fellow enthusiasts,
Quick question, do transfer cases have a synchro gear? Mine used to be able to shift on the fly. Now I must stop to get it in, coming out whilst moving is easy and smooth.
You should be able to shift from 2hi to 4hi without stopping so long as the freewheel hubs are locked.
If your tyres are different sizes, your hubs are seized, or some part of the drivetrain is broken such that the front shaft and rear shaft aren't rotating at the same speed then you won't be able to shift. You shouldn't change 4hi to 4lo on the fly, there is no synchromesh.
Are both hubs engaging? That would be the first thing I'd check.
Users browsing this forum: No registered users and 81 guests
