It is currently Sat Aug 15, 2026 2:20 am
Vehicle: tin top sj70
Post Posted: Tue Nov 27, 2012 6:35 pm
Out of no where my indicators stopped working. Nothing happens at all when I indicate. But yet my hazard lights work. Anyone know whats up with that ?
Vehicle: Yellow Ute
Post Posted: Tue Nov 27, 2012 6:37 pm
Checked the fuse?
Post Posted: Tue Nov 27, 2012 7:03 pm
Already done
Post Posted: Tue Nov 27, 2012 8:44 pm
My LJ ute does the same thing, dunno why.
Post Posted: Tue Nov 27, 2012 8:46 pm
Could also be dirty/corroded contacts on the combination switch. The hazards operate off a separate switch on to of the column.
Vehicle: 96 vit hardtop
Post Posted: Tue Nov 27, 2012 10:21 pm
I'd also check the relay mate, good chance its gone bonkers. Thats the thing that makes it flash. Square or round little module somewhere that clicks.
I'd replace it to be sure - often called a 'flasher' believe it or not!
Vehicle: SJ80, SE416
Post Posted: Wed Nov 28, 2012 8:24 am
Used the hazard lights lately? The problem could be in the harards switch - there are 2 sets of contacts in it!
The hazard switch has a set of contacts which stop normal indicator operation when the switch is on and obviously these contacts don't get used much.
Try working the hazard switch on/off a few times.
Post Posted: Wed Nov 28, 2012 10:55 am
Had the same problem until i found a broken wire to the earth
Vehicle: Suzuki Sierra SWB Soft-top
Post Posted: Thu Jan 08, 2015 7:30 pm
I've got the same problem with my sierra. I've replaced my combination switch, my flasher relay got replaced 3 months ago and the fuse is good... It seemed to start playing up couple of weeks ago then when my car broke down (fuel pump relay blew) I used my hazards. 1 week later once the car was fixed no indicators just hazards.... Please help as this is starting to annoy me
Post Posted: Fri Jan 09, 2015 12:39 am
masterA is, I think, on the right track with this.
An overwhelming percentage of electrical problems are caused by poor earth connections.
Start tracking down the black wires and locate where they attach to sheet-metal. Be sure that they are all making good contact.
Remember, if you were as old in "car years" as many of our trucks, you would probably be in a rest home...
-Ack
http://www.acksfaq.com
88, 88.5 SJ413
Vehicle: 98 sierra coily
Post Posted: Fri Jan 09, 2015 11:09 am
+1 this was my problem and solution.
Post Posted: Fri Jan 09, 2015 11:54 am
I replaced the whole combination switch...
Users browsing this forum: No registered users and 20 guests
