It is currently Thu Aug 13, 2026 10:19 pm
Vehicle: 09 Jimny JX
Post Posted: Sun Nov 16, 2014 10:15 am
is there a trick or secret to removing the body clips that hold the plastics on the Jimny?
some of them twist out. but others are a pain. want to check here before i get rough with them and most likely break them :roll:
Post Posted: Sun Nov 16, 2014 10:48 am
If they are the double square ones like the Grand Vitara then they just pull out with care - they are genuine Suzuki parts and cot 4 dollars each.
Vehicle: Suzuki Jimny 2010
Post Posted: Mon Nov 17, 2014 4:41 pm
You can buy panel removal tools that are plastic and have an end on them kind of like a claw hammer. If you slip them in between the clip and panel they pop out. I presume you're talking about the ones on the doors?
Post Posted: Mon Nov 17, 2014 7:52 pm
i got the ones on the doors by grinding a 10mm open spanner thin, with a slight bend (much like the tool you described) and that worked perfect. problem was the rear guards, where you cant get behind to push them out
Post Posted: Mon Nov 17, 2014 7:55 pm
some of them ones you need to push in the pin further then reset them when putting back in...
Users browsing this forum: No registered users and 74 guests
