I Didnt think it was adjustable. Can be checked. Main thing to check is the slack of the Accelerator cable, if to slack can affect throttle response but thats about it.
THROTTLE POSITION SENSOR (TP SENSOR) Inspection 1) Disconnect negative cable at battery and coupler from TP sensor. 2) Using ohmmeter, check resistance between terminals under each condition given in table below. TERMINALS RESISTANCE Between 1 and 3 terminals 4.0 – 6.0 k Between 1 and 2 terminals 0.02 – 6.0 k , varying linearly according to throttle valve opening If check result is not satisfactory, replace TP sensor. 3) Connect TP sensor coupler securely.
Users browsing this forum: No registered users and 7 guests
