| Grand vitara 1 inch body lift http://auszookers.com/forum/viewtopic.php?f=37&t=48555 |
| Author: | 2000 gv [ Tue Nov 25, 2014 6:48 pm ] |
| Post subject: | Grand vitara 1 inch body lift |
Who's fitted a 1inch body lift and is there much work to it? My cars a 2000 grand vitara |
| Author: | ninjamoses [ Tue Nov 25, 2014 7:21 pm ] |
| Post subject: | Re: Grand vitara 1 inch body lift |
May as well go 2 inches mate if you are going to the effort of doing it. Only positives of a 1" vs a 2" is you could probably get away without a steering shaft spacer. Apart from that its going to be just as much work either way. |
| Author: | 2000 gv [ Tue Nov 25, 2014 9:12 pm ] |
ninjamoses wrote: May as well go 2 inches mate if you are going to the effort of doing it. Only positives of a 1" vs a 2" is you could probably get away without a steering shaft spacer. Apart from that its going to be just as much work either way. Hey mate I'm the fella who bought your window switch off you the other night. Is it an easy DIY job or would you recomend getting someone to fit it for me? |
| Author: | Duebakka [ Wed Nov 26, 2014 8:19 am ] |
I did 1" body lift my self. Wasn't too bad to fit but you will need a steering spacer and also keep in mind your front and back bumpers will need modifying to fit |
| Author: | 2000 gv [ Thu Nov 27, 2014 11:25 pm ] |
Duebakka wrote: I did 1" body lift my self. Wasn't too bad to fit but you will need a steering spacer and also keep in mind your front and back bumpers will need modifying to fit Where can you buy a spacer from? |
