Vehicle: 1997 coily, 1.3lt engine stock
Posted: Tue Dec 02, 2014 8:24 pm
Hey guy just wondering if a jimny hub nut socket will work on a coily? As I'm trying to reach my kingpin and wheel bearings? Cause I have the infamous death wobbles hahaha
Can't help with that question - but SE Vitara hub socket would fit.
If you can't get one, I have never had a problem using a hammer and a 5 or 6mm pin punch to loosen and tighten the hub nut. Never had a problem with bearing life either after re-packing old bearings and they are still good after 80K km + using this method.
Posted: Thu Dec 04, 2014 11:25 pm
Hey mate, You won't need a hub nut socket for the coily, as Reubs said you use a punch. Check out this thread for some pics. viewtopic.php?f=5&t=48105&hilit=dec
Users browsing this forum: No registered users and 41 guests
