It is currently Fri Aug 14, 2026 6:12 pm
Vehicle: 98 sierra coily
Post Posted: Mon Dec 22, 2014 6:03 pm
hi guys.
im in the process getting my coily on the road and have some trouble finding the right parts.
the shoes i got off ebay were 1539 which ive since learned are the wrong ones even though the description said fits up to 98'. should have researched first.
a search on here does not show anything specific to the coilys except the WT ones fit 1617 is that correct?
got some 96-08 jimny +sierra js80 wheel cyld which also were incorrect jbs brakes 7791,7792.
cant find any except genuine suzuki from suzystore at 98 bucks each, where else can i find coily wheel cyl from??
thanks.
Vehicle: Coily.
Post Posted: Mon Dec 22, 2014 7:51 pm
We had the same problem,Repco listing is also wrong.Picked up 2 from a wrecker that were in good nick with the thought of re-conditioning the originals but haven't needed too so far.
Greg at 4WD parts can supply the correct brake shoes cheaply and also genuine Suzi brake cylinders but obviously they are pricey.
Post Posted: Tue Dec 23, 2014 6:19 am
thanks mate so no aftermarket around hey? bummer, might go the wreckers too.
Vehicle: Coily.
Post Posted: Tue Dec 23, 2014 6:32 am
Any specialist brake mob can re-co your brake cylinders,if they can't get the exact size seals they just bore centre to suit what they can get, same with brake shoes,they can bake on new linings on your old ones,the major brake places do it all the time for veteran/vintage cars.
Post Posted: Tue Dec 23, 2014 6:52 am
Post Posted: Tue Dec 23, 2014 7:03 am
they are the same shape but different raised bits? and would bolt on as the raised bit goes through the back?? dunno.
Vehicle: Coily.
Post Posted: Wed Dec 24, 2014 8:23 am
I don't know but i thought there was a listing for left side and a different listing for RHS which yours is in photo.If you get it sorted post details of the new cylinders that fitted for future reference.
Post Posted: Wed Dec 24, 2014 9:05 am
just drill a bigger hole for the "raised bit"
Post Posted: Wed Dec 24, 2014 12:29 pm
well i dont think i even need to do that? the oval raised base that houses both yellow inlets bits bolts through a hole where the brakes are mounted dont they? if so the hydolic pipes will still go on given they're only a cm apart??
dammit i need the car here!
Vehicle: Sierra
Post Posted: Fri Dec 26, 2014 6:46 am
Hmm thinking I may have the same problem in a couple of days.....did these fit or not??
Post Posted: Fri Dec 26, 2014 7:32 am
the cylinders? sorry mate dont know, i returned them. (ebay seller was in the next suburb)
when i get the car here in a few days i will look into it again
Vehicle: Sierra
Post Posted: Fri Dec 26, 2014 7:53 am
No worries
Vehicle: Sierra
Post Posted: Fri Dec 26, 2014 10:59 am
Stripped mine this morning and yep got the same problem, they will fit if you want to bend the brake lines to reverse them but the the clamps for the brake lines wont line up properly. Going to try to get the correct ones though as once you bend those lines there normally a prick to line back up and get the thread started again.
Post Posted: Sat Dec 27, 2014 2:15 pm
That a pic of the ones you have and email greg at 4wd products
There is like 5 different shoes for the rear of a sierra and it has nothing to do with year . Its all over the place with suzuki.
Vehicle: Coil Sierra
Post Posted: Sat Dec 27, 2014 3:40 pm
Db1617 or N1617 for the coily rear shoes.
Vehicle: Sierra
Post Posted: Sat Dec 27, 2014 11:17 pm
What about the wheel cylinders? Do you have a part number for those?
Vehicle: Sierra
Post Posted: Wed Jan 07, 2015 11:29 am
So I just got told they are only available genuine and for fun rang Suzuki, $160 ea.....$140 trade Part numbers are 5340270AAO l.h. side and 5340170AAO r.h side ex Japan.
Anyone able to tell me if the SJ 70 cylinders are 13/16ths dia as the ports are at least correct and they look like they will fit ok.
Post Posted: Wed Jan 07, 2015 11:37 am
they are usally marked on the out side with a diameter aren't they?
Vehicle: Sierra
Post Posted: Wed Jan 07, 2015 12:11 pm
yeah the ones I have arte 13/16ths but not sure with the SJ70 cylinders
Vehicle: SJ80, SE416
Post Posted: Wed Jan 07, 2015 2:17 pm
Suzistore list genuine ones as per your part numbers above for $99 ea. Still expensive but much cheaper than from a local Suzuki dealer.
Vehicle: Sierra
Post Posted: Wed Jan 07, 2015 2:58 pm
Just got a call it looks like one stop suzi shop has them for $65 ea....heading down tomorrow to have a look and hopefully grab a set.
Question though if the drums and shoes are the same partnumber for both SJ70 and SJ80 why is there different wheel cylinders? Coincidently SJ70 are $55 and SJ80 are $99......different dia?
Vehicle: Sierra
Post Posted: Thu Jan 08, 2015 10:13 am
Wrong ones again, starting to get a little frustrating.....Dave at one stop is a trooper though and still trying to source the correct ones
Vehicle: Coily.
Post Posted: Thu Jan 08, 2015 9:05 pm
Yep,went thru the whole saga last year,parts listing from Repco/Supercheap/Ebay etc are all wrong,i think you have to source genuine,2nd hand from a wrecker or get the originals re-coed.
If you do suss something out please post here for future reference.
Post Posted: Fri Jan 09, 2015 10:58 am
@ tonner, haha so u were the one? i rang up yesterday and he said he was trying to sort this out for someone just as i rang.LoL.
time for me to bite the bullet and pay 99 from suzystore, i need a timing cover too.
Vehicle: Sierra
Post Posted: Fri Jan 09, 2015 1:51 pm
Yep still trying to get on top of it, let me know if the ones from Suzystore are the correct ones.
Vehicle: Sierra
Post Posted: Wed Jan 21, 2015 7:03 pm
Apparently its new or re-sleeved as the only options....best price is out of WA
Users browsing this forum: No registered users and 58 guests
