It is currently Fri Aug 14, 2026 10:30 am
Vehicle: 92 Sierra
Post Posted: Tue Dec 23, 2014 8:32 am
Hi, I'm swapping out the sierra motor for a 2000 baleno g16b. I have searched for hours to find a wiring diagram that lines up with the ecu that ive got and had no success. Is the color coding the same on all these models but they change the pin # on the ecu?
Cheers Ozz
Post Posted: Tue Dec 23, 2014 9:05 am
if you take the case off of the ecu. most o them have letter codes to tell you what the pins are for.
Vehicle: Drover pickup turk
Post Posted: Tue Dec 23, 2014 9:33 am
http://www.ptjau.com/images/sierra/bale ... ringv1.pdf
^ that's the guide I used for my 2000 baleno, It does mention this;
NOTE: This wiring diagram assumes you have a G16B from a Suzuki Baleno with manual transmission, has no immobiliser, has no EGR, has a single wire
oxygen sensor and has a carbon canister with purge valve.
Is yours different from those features above?
I like the tuna here
Vehicle: 92 Sierra
Post Posted: Tue Dec 23, 2014 11:29 am
I have now taken the cover off and it all makes sense now. I was going off the outside pins and nothing seem to line up.
Mine is a bit different from the above diagram as i have an Immobilizer an EGR fitted which must change the layout a bit i'm suspecting, but I could be wrong.
Thx for the help and quick responses
Vehicle: 92 Sierra
Post Posted: Wed Dec 24, 2014 9:42 pm
Another one for yous what do I do with the Immobilizer and EGR output can they be shorted or do they have fail safe in them, or if i have to put resistance to it what resistance would they require.
Thanks Ozz
Post Posted: Thu Dec 25, 2014 3:10 am
The immo can't be removed. The EGR is best kept as it improves mid throttle response and economy. Immobilizer ECUs have a slightly different pinout around the cam sensor, what part number is the ECU? Can you post a pic of the PCB?
Vehicle: 92 Sierra
Post Posted: Wed Dec 31, 2014 6:29 am
https://imageshack.com/i/hlIYxboPj
https://imageshack.com/i/f0AZwRzVj
https://imageshack.com/i/f0Oke1dIj
Here are some links to pics of the unit
Post Posted: Wed Dec 31, 2014 11:46 pm
Can you post a pic of the full PCB, if I can see the processor and the PCB part number I can tell you if its reflashable.
Vehicle: 92 Sierra
Post Posted: Thu Jan 01, 2015 7:44 am
https://imageshack.com/i/p4dfVh6wj
Thanks for the help
Post Posted: Thu Jan 01, 2015 7:49 am
You can't flash that ECU but it must be a non-immobiliser ECU because the memory chip for the immo codes is not fitted.
Vehicle: 92 Sierra
Post Posted: Thu Jan 01, 2015 9:25 pm
Thanks for the help on that one Rhinoman.
What is the best way integrate the wiring together
ie cut the baleno fuse box out of the system or leave it in.
should i leave the diagnosis connector in the circuit
I'm looking at cutting out the fuse box and diagnosis points just to minimize connections
Post Posted: Thu Jan 01, 2015 11:18 pm
I would leave the diagnostic connector in place, it could save you having a real headache diagnosing any issues later. The Baleno loom is a bit of overkill, I replaced the Baleno fuse box with a smaller one with just the EFI fuses.
Vehicle: Suzuki Sierra
Post Posted: Mon Jan 26, 2015 4:32 pm
im putting a G16b From a baleno into my sierra, having a few issues with wiring, been doing research, and every decent thread leads to pj zooks diagram. going from the box with the main fuse to the engines fuse/relay box seems to be spot on, just unsure about following the lume back inside the cab, ive stripped out the wires/relays/fuses i believed were not required A/C,ect... the wires from the main/FI and Fuel pump relay go up to a square blue connector which is very close to the pcm connector pj zook lables as A. Have tried to follow a few wires back according the connector diagram and the just dont seem to go to the right places. ive seen the page says assuming you have single wire 02 no egr and non immobilized,which i thought i had, however in beginning to have doubts. is there away i can confirm my harness matches the diagram.
also has anyone got a photos of a completed harness laid out? would just like to see how many wires/connectors remain.
any input would be appreciated
cheers Ash..
Users browsing this forum: No registered users and 45 guests
