It is currently Sat Aug 15, 2026 3:20 am
Vehicle: MG410 WT
Post Posted: Tue Jan 06, 2015 9:51 am
Gday fellas,
In the Vit i have been hearing a really bad screeching noise from the rear left wheel.
It only screeches when im going 130+.
I have suspected it could be a wheel bearing, but if anyone has any other suggestions on the problem it would be greatly appreciated.
Thanks in advance.
Vehicle: WT sierra, GU CRD
Post Posted: Tue Jan 06, 2015 10:40 am
If I recall, you are in Darwin?
You've been playing in the black mud that is frequently found in low lying areas outside of Howard Springs and near Palmerston? I'd say from personal experience your wheel bearings are fucked and soon will be your starter motor and seals on the lower parts of the car. Its not the greatest stuff if it gets inside the bellhousing either.
I love ZD30. :)
Vehicle: MG410 WT
Post Posted: Tue Jan 06, 2015 11:18 am
This is correct,
I dont like playing in that black mangrove mud, but who knows what the previous owner got up to.
But you are right about the seals as i have noticed some green liquid coming out of the rear diff where the drive shaft connects to!
Post Posted: Tue Jan 06, 2015 11:23 am
Nah green diff fluid is perfectly normal, it's assembly lube used when setting up the suzuki circle spin ratio for the diff.
It's only a problem when it changes from green to red. The red indicates that you should stop and not proceed past go.
Vehicle: MG410 WT
Post Posted: Tue Jan 06, 2015 11:29 am
Ok cheers, Should it be leaking though?
Vehicle: Which one?
Post Posted: Tue Jan 06, 2015 12:27 pm
:rofl:
Post Posted: Tue Jan 06, 2015 12:55 pm
henno wrote:
:rofl:
i'd be more concerned if your sump fluid ran dry or went red... the rocket cover will implode due to the vacuum created by the spinning components not splashing around in the swooshy green stuff.
Vehicle: MG410 WT
Post Posted: Tue Jan 06, 2015 12:59 pm
Its so hard to decipher a troll from a legit answer these days
Post Posted: Tue Jan 06, 2015 1:30 pm
No. But when you do wheel bearings you do seals as well which is the good news for your wallet.
It also shouldn't be green unless someones made green diff oil, usually if its had water (a legit concern up here) it comes out as milky sludge.
Did you buy this car off of Steve?
I love ZD30. :)
Post Posted: Tue Jan 06, 2015 1:49 pm
Sorry, I'll try to remember to use italics in the future for those replies, it's hard to do all that funky jazz on a phone. :oops:
Green sump fluid FTMFW Armsup
Vehicle: MG410 WT
Post Posted: Tue Jan 06, 2015 3:44 pm
Nooooo way, i did a bit of research on Pirate4x4 and Outerlimits and looked through his builds
Way too much dodgy shit
Post Posted: Tue Jan 06, 2015 10:10 pm
Oh ok. Good luck with your wheel bearings and seals its not that bad of a job.
Use the right sized drivers, I bought a bearing and seal driver kit. It makes life easier and you'll use it a bit if you continue to mess with cars, motorbikes or anything.
Or just find the right sizes of pipe. But it was easier for me to get a kit.
I love ZD30. :)
Users browsing this forum: No registered users and 18 guests
