It is currently Fri Aug 14, 2026 2:05 am
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Feb 04, 2015 8:32 am
Hi all
I want to convert my mean mother 150l/s air compressor which doesn't have pressure sensor or switching capability into a more automated unit that i can use with lockers.
can anyone suggest reliable parts and wiring diagrams to set this up?
cheers
JK
Vehicle: 85 SJ413
Post Posted: Wed Feb 04, 2015 10:06 am
I have one of these Viair pressure switches controlling my a/c compressor onboard air:
http://www.ebay.com/itm/Viair-90102-Air-Ride-Suspension-Pressure-Switch-110-145-PSI-1-8-Male-NPT-/360982537727?pt=Motors_Car_Truck_Parts_Accessories&hash=item540c3c65ff&vxp=mtr
That eBay listing also has a wiring diagram showing how to wire it up with a relay to switch the compressor on and off.
Ben
Post Posted: Wed Feb 04, 2015 11:16 am
You can buy 100 and 150 psi switches from ARB pretty cheap. You'll need a small tank to run the lockers- they need some "inrush" air so you can't just run a manifold. ARB can also supply a little tank/manifold which can integrate the pressure switch.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Feb 04, 2015 11:21 am
thanks Ben/ Steve. i was intending to run a small tank in the right rear sub frame above the wheel arch. looks like it will work a treat.
Vehicle: Xr6
Post Posted: Wed Feb 04, 2015 11:10 pm
I currently have a tank there jezza, if you need any info let me know, it's wried up to a compressor/pressure switch and a manual switch too.
Vehicle: '94 suzuki maruti
Post Posted: Thu Feb 05, 2015 8:35 pm
something like this would be ideal. ebay also sells the pressure switches pretty cheap.
http://www.ebay.com.au/itm/Air-Compress ... 4d2bebe972
probably too many ports for what you want, but theres smaller options available.
Users browsing this forum: No registered users and 17 guests
