| Air compressor conversion/setup for lockers http://auszookers.com/forum/viewtopic.php?f=37&t=49232 |
| Author: | Jezza86 [ Wed Feb 04, 2015 8:32 am ] |
| Post subject: | Air compressor conversion/setup for lockers |
Hi all I want to convert my mean mother 150l/s air compressor which doesn't have pressure sensor or switching capability into a more automated unit that i can use with lockers. can anyone suggest reliable parts and wiring diagrams to set this up? cheers JK |
| Author: | BenT [ Wed Feb 04, 2015 10:06 am ] |
| Post subject: | Re: Air compressor conversion/setup for lockers |
I have one of these Viair pressure switches controlling my a/c compressor onboard air: http://www.ebay.com/itm/Viair-90102-Air-Ride-Suspension-Pressure-Switch-110-145-PSI-1-8-Male-NPT-/360982537727?pt=Motors_Car_Truck_Parts_Accessories&hash=item540c3c65ff&vxp=mtr That eBay listing also has a wiring diagram showing how to wire it up with a relay to switch the compressor on and off. Ben |
| Author: | Gwagensteve [ Wed Feb 04, 2015 11:16 am ] |
You can buy 100 and 150 psi switches from ARB pretty cheap. You'll need a small tank to run the lockers- they need some "inrush" air so you can't just run a manifold. ARB can also supply a little tank/manifold which can integrate the pressure switch. Steve. |
| Author: | Jezza86 [ Wed Feb 04, 2015 11:21 am ] |
thanks Ben/ Steve. i was intending to run a small tank in the right rear sub frame above the wheel arch. looks like it will work a treat. |
| Author: | Xr6_matt [ Wed Feb 04, 2015 11:10 pm ] |
I currently have a tank there jezza, if you need any info let me know, it's wried up to a compressor/pressure switch and a manual switch too. |
| Author: | whincup [ Thu Feb 05, 2015 8:35 pm ] |
something like this would be ideal. ebay also sells the pressure switches pretty cheap. http://www.ebay.com.au/itm/Air-Compress ... 4d2bebe972 probably too many ports for what you want, but theres smaller options available. |
