It is currently Thu Aug 13, 2026 11:42 pm
Vehicle: 98 sierra coily
Post Posted: Fri Feb 06, 2015 4:51 pm
hi all, trying to replace the timing cover on my sj80 which i think has had an engine swap caus it has g13a stamped on the block not g13ba which i think it should be, correct? anyway ordered a sj70 one from suzisport i thought would be it as it has no inspection hole like suzisport shows on the sj80 parts.. DOESNT FIT!!!!
sj80 part no 11390 51g00g
sj70 part no 11390 82010g
mine 11390 60a11 which google tells me its from a suzy sidekick 1.6 and is about an inch longer.
what hybrid bloody engine do i have??
also while im here, does a sj80 have a battery/alternator light?
thanks fellas.
Vehicle: 1997 Sierra SJ80
Post Posted: Fri Feb 06, 2015 6:11 pm
Can you chuck up some pics, or send them to someone who can on your behalf?
Post Posted: Fri Feb 06, 2015 6:46 pm
yeah i can do pics, but of what? the timing cover? looks identical just an inch taller. or the engine?
Post Posted: Sat Feb 07, 2015 3:04 am
Looks like they sent you the wrong part - assuming you specifically mentioned G13 in you order, which you probably did if you ordered online with one of those Internet list-box thingies.
G16 covers are longer because the block is about an inch (your words, not mine! :rofl: Sorry - everyone gives me crap about how I am occasionally Metrically-challenged in my posts... ) longer.
Call Suzisport and get a replacement for the wrong part they sent you..
-Ack
http://www.acksfaq.com
88, 88.5 SJ413
Post Posted: Sat Feb 07, 2015 8:05 am
Nah, i think they sent the right one (to what i ordered)the part numbers match up.
its my engine that is all faaaarked up! it is stamped g13a but is a inch longer and has a vitara 1.6 timing cover?? i don't get it.
interestingly, in the 4x4 facebook page that i fount it on there was a discrepancy on the motor was in it, an old owner said it was a 1.6 but the seller said it wasn't.
Post Posted: Sat Feb 07, 2015 10:44 am
Someone restamped a g16 to your engine number
Post Posted: Sat Feb 07, 2015 10:47 am
I recall a while ago someone had the same issue.
number was stamped on very wonky too. Was a thread with pics iirc
viewtopic.php?f=5&t=15434&p=245864&hilit=stamped#p245864
Post Posted: Sat Feb 07, 2015 11:26 am
Capacity is cast onto the block on the lhs near the timing cover on the bell housing. If that's been ground off then obviously someone was trying to pass off a G16 as a g13 for registration purposes.
Post Posted: Sat Feb 07, 2015 12:28 pm
To amplify on Steve's post, It should read 1324CC for a G13A, 1296 for a G13B and 1590CC for a G16 on the edge of the engine block right next to the timing plug on the Sierra gearbox. All of this is located on the extractor side of the engine.
As usual, an overall picture of the top of the engine and the rear, extractor edge of the engine would be helpful....
I hope that this helps!
-Ack
88, 88.5 SJ413
Post Posted: Sat Feb 07, 2015 1:28 pm
yeah i think its a 1.6 restamped 1.3, . so technically this should have a mod plate yeah? also has the thick adapter plate mentioned in that other thread.
couldnt find cc"s though but has s16 top of block near timing cover
sooo, is this all 1.6 vitara? head? dizzy? carby?
also does a sj80 have a battery/alternator light?
Post Posted: Sat Feb 07, 2015 1:48 pm
Its passenger side, maybe hidden/difficult to see due to the extractors.
can be at the top of the block on passenger side, near the back. or on the top of the block on the back, passenger side of the back.
A pic of engine number and area would be helpful.
Post Posted: Sat Feb 07, 2015 2:34 pm
The motor mounts look very 1.3-like to me as does the valve cover.
The distributor looks too old-style for a 1.6 8-valve.
Then again, I'm way the eff over here where the water allegedly swirls down the turlet clockwise...
A pic of that flat area where the displacement is cast into the block next to the gearbox is what needs to be seen.
-Ack
88, 88.5 SJ413
Post Posted: Sun Feb 08, 2015 8:58 am
Thats a g16. You c a n tell by the very first pic . To the left of the s16 that rectangular part of the casting is flush with the head surface on a g13. Also the part number of your original timing cover.
Vehicle: SJ80, SE416
Post Posted: Mon Feb 09, 2015 3:42 pm
thanks fellas.
Yes it does.
Users browsing this forum: No registered users and 84 guests
