It is currently Thu Aug 13, 2026 10:27 pm
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Mon Feb 09, 2015 3:58 pm
In a manual, the gearstic vibrates because things are slightly out of balance. Correct?
So if thats geting worse? Bearings?
Post Posted: Mon Feb 09, 2015 7:23 pm
Could be the rear engine mount is hardened / cracked?
Post Posted: Mon Feb 09, 2015 8:16 pm
Uni joint.
Shift sheet wear
bent transfer mount
and wot alien said.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Mon Feb 09, 2015 8:31 pm
Yep just at idle that I noticed it
Vehicle: Vitara SV420
Post Posted: Mon Feb 09, 2015 9:55 pm
What is your RPM at idle with engine at operating temp, no loads or A/C?
Base idle out, dirty EGR/throttle valve or dodgey IAC motor maybe.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Tue Feb 10, 2015 7:37 am
RPM looks stable. have recently replaced the clutch at 28,000K as the bearings were dead because the car has been doing too much swimming.
just looking for signs that my gearbox needs a rebuild
Users browsing this forum: No registered users and 64 guests
