It is currently Thu Aug 13, 2026 9:45 am
Vehicle: '83 SJ40T G13BA 5-Speed
Post Posted: Tue Feb 24, 2015 4:39 pm
Does anyone know if there is any difference between the transfer cases in a '83 Sj40T and an '86 SJ50?
Thanks from Jack
Post Posted: Tue Feb 24, 2015 4:54 pm
Yep.
Depends on a bit on the variant of sj40T.
If your car has a 4WD light and there is a 4WD light switch on the transfer case, the difference is the gearing and the flanges. Both gearing and flanges can be swapped as appropriate, the cases are basically identical.
SJ50: High range 1.409, Low Range 2.21
SJ40: High range 1.58, Low Range 2.55
If your car has no 4WD light or provision for a light switch on the transfer case, gearing is the same as the 4WD light SJ40 case but there is nothing interchangeable.
Post Posted: Tue Feb 24, 2015 5:28 pm
A 4WD light on the dash?
Post Posted: Tue Feb 24, 2015 10:10 pm
AND the switch on the case. bear in mind in the last 32 years things might have been swapped.
Users browsing this forum: No registered users and 40 guests
