The FSM suggests the sump can be removed without pulling the engine - the front diff & rack & pinion will need to be removed.
Assuming that you're doing this because of a suspected leak - I suggest you be very certain that it is the gasket before starting - it's quite unusual for RTV FIP gasket to suddenly start leaking, and the H series engines have quite a reputation for oil running down from leaks higher up (possibly around the timing cover, the oil filter, and the oil pressure switch) and appearing to come from that area.
Users browsing this forum: No registered users and 68 guests
