It is currently Tue Aug 11, 2026 3:23 pm
Post Posted: Wed Apr 15, 2015 8:58 am
Hi all.
Sorry for the noob questions. Found a tidy xl7 for a steal but it has a ticking noise from the "alternator" apparently.
im going to see it this arvo, what do i look for?
How do i identify the noise?
Whats the worst case scenario? I.e how much should I budget for repairs?
Thanks in advance
Post Posted: Wed Apr 15, 2015 9:16 am
could be the timing chain/tensioners
Post Posted: Wed Apr 15, 2015 10:20 am
Its got 180k on the clock so could be.
Should i pass on it if it is?
Vehicle: 1993 Sierra 1.6 efi Vit motor,
Post Posted: Wed Apr 15, 2015 12:24 pm
Check it with a stethoscope.
Post Posted: Wed Apr 15, 2015 12:42 pm
Thats a good idea.
Just trying to work out if the chains are an easy enough job to warrant buying it.
Ive done timing belts in the past but never a chain
Post Posted: Wed Apr 15, 2015 1:09 pm
It's a pain to do but it's not a hard job. You have to take a lot off the engine to get to the chains if you follow the manual but timing it is pretty easy.
Line the dots up and put it on. Same as a belt. I wouldn't pass on a good car if the rattle is just chains or tensioner related.
Post Posted: Wed Apr 15, 2015 1:18 pm
I might start with a good service first if it seems like the chains then go from there.
It wont be a daily for a while yet so might have to go have a squizz. Its bloody cheap thats for sure!
Post Posted: Wed Apr 15, 2015 1:32 pm
You'd really want to check it from a cold start (ie. after sitting over night) - that's when the timing chain noise will be at it's worst. The hydraulic lifters can also make a similar noise.
Aftermarket oil filters can make the rattling worse (the oil filter is down low on the RHS of the engine - as you're facing the engine bay.) I've found Ryco filters really bad for it.
I wouldn't class changing the chains as an easy job; I've done timing belt changes before but would be hesitant to attempt doing the chains/ tensioners.
Users browsing this forum: No registered users and 77 guests
