It is currently Tue Aug 11, 2026 4:01 am
Vehicle: SJ70 Tintop, SJ51T, 97 Coily
Post Posted: Mon May 04, 2015 9:34 am
I getting pretty clost to doing a 1.6a engine swap into my 85 Drover and was advised to use the vitara gearbox as well to handle the extra power.....might also save buying a BenT kit. Will it fit and what mods will need to be done if I use the Vit box? or am I better off using the Sierra box and adapter.
Appreciate any advice
Post Posted: Mon May 04, 2015 9:36 am
Shortened jack shaft, opened up transmission tunnel, custom gearbox mount.
Post Posted: Mon May 04, 2015 9:53 am
Thanks for the quick reply....Is it worth the effort or not really reqd?
Post Posted: Mon May 04, 2015 11:00 am
You may also need a shifter mod
Jackshaft mods will be close to same cost as a BenT kit
To fit he g16 you need to pack the passenger engine mounts out a touch, and on the drivers side, you can tilt the engine over and a use a little plate to get it to fit (have to drill a hole in the chassis engine mount for the nut and bolt to pass through)
A BenT kit and using sierra gearbox, is a shit load easier, it comes with instructions.
While the gearbox isn't as strong it'll work fine.
Id only bother if I was going to use either of the vit auto, and/or if intending to use a vit xfer and non sierra diffs.
Post Posted: Mon May 04, 2015 11:36 am
Cheers for the advice, BenT kit it is then.....I hate creating problems for myself..lol
Users browsing this forum: No registered users and 89 guests
