http://auszookers.com/forum/
ticking noise from my SQ625 - UPDATE
http://auszookers.com/forum/viewtopic.php?f=37&t=50001
Author:  swifty_ano [ Sun May 03, 2015 4:09 pm ]
Post subject:  ticking noise from my SQ625 - UPDATE
Hey guys,
Finally bought a 2000 Grand Vitara. The owner said it had sat for 1.5 months without being run and now it has a ticking noise coming from the front of the motor which is constantly there.
it's quite a loud tick and doesn't seem to get louder with revs increase.
The speed of the tick gets faster with the revs but will pretty much disappear when they get to a certain rpm.
I drove the car 1.5 hours on the highway hoping that a good run would sort the issue out but it didn't.
As soon as I got the car home, i gave it an oil change it desperately needed. When i put the Nulon engine flush in and started her up, the tick had completely disappeared after 2 minutes of running.
Unfortunately, that quietness was short lived. Once I changed the oil(repco) and oil (5-30 full synthetic) the noise instantly returned and I cannot get it to quieten down.
I bled the lifters as per the bulletin, 2000rpm for 20 minutes but that made no difference.
I also added some Nulon stop tick to the oil but I am yet to run the car as now i am concerned that it might be the timing chain and if it is, the noise is constant so it could be very close to letting go?
I tried to but a stethoscope today but i couldn't find one.
Any input would be greatly appreciated...how I can identify the cause? Should i drive the car and see if the stop tick additive works?
Author:  Joe [ Sun May 03, 2015 4:31 pm ]
Post subject:  Re: ticking noise from my SQ625
Kate's gv started to get a timing chain tick, i done a service and was still there so just gave it a good rev to 6500 twice and that clicked the chain tensioner over and no more noise
Author:  swifty_ano [ Sun May 03, 2015 4:43 pm ]
Was it a constant tick? I read something about giving it a good rev but never understood how it works? Know my luck mine will jump a tooth haha
Author:  Joe [ Sun May 03, 2015 5:06 pm ]
Yeah constant tick got worse under load, i'm not sure how it works but i remember Steaky said something about it years ago so i gave it a go and it worked
Author:  swifty_ano [ Mon May 04, 2015 7:25 am ]
Well potentially good news. I gave it a bit of a hard time on the way to work this morning (didn't thrash it but I didn't baby it like it did yesterday) when I got to work the noise had disappeared.
I won't count on it being fixed till after a few days but this is the first times its been quite on its own, so fingers crossed.
I wish I had of waited to put the "stop tick fluid" in because now I'll have no idea what cured it.
Author:  swifty_ano [ Mon May 04, 2015 12:12 pm ]
False alarm. Well that didnt last long.
Should I order my timing chain kit haha
Author:  swifty_ano [ Tue May 05, 2015 9:38 am ]
Post subject:  Re: ticking noise from my SQ625 - UPDATE
UPDATE!
So it seems like it is a timing chain rattle. Since driving it, the noise has now become much quieter (still very noticable) but much quieter then it was.
The noise now disappears once the cars warmer.
Anyone wanna help me change the timing chain ! :)
Author:  murcod [ Tue May 05, 2015 4:17 pm ]
What brand oil filter are you using? I've found some brands (eg. Ryco) can make the rattle sound a lot worse. Genuine Suzuki filters seem to be best.
Author:  swifty_ano [ Tue May 05, 2015 4:29 pm ]
I just used a repco brand? Any experience?
Author:  henno [ Tue May 05, 2015 4:51 pm ]
Use a genuine filter on the H-series engines.
Author:  swifty_ano [ Tue May 05, 2015 7:17 pm ]
Would it cause a tick to stick around for 5 minutes or so?
Author:  murcod [ Tue May 05, 2015 10:11 pm ]
Could do. When I was using Ryco (they've since changed the fitment) there were two different construction oil filters they sold under the same part number. One was sort of okay, the other gave rattling for an extended period of time.
Then I was using K&N and they were better. Last change I used the genuine filter (it was cheap too) and it does seem to be quieter. The wife normally drives it from a cold start - so I haven't heard that yet, but warmed up it was the quietest it's ever been. (Note: I have electric thermofans so any rattling is very obvious.)
Author:  swifty_ano [ Wed May 06, 2015 6:10 am ]
Oh ok. Who would have thought. I will have to give a genuine a shot next oil change.
Thanks for the input
Author:  Joe [ Thu May 07, 2015 6:45 pm ]
Mate i wouldn't be to worried about a little rattle when it's cold, just swap that filter over to a gen suzuki one (less then 20 bucks) and change ya oil every 5000 kms
Built4thrashing had the same issue
Built4thrashing wrote:
gregdixon wrote:
I give it a good high rpm high load run. Lets the tensioner jump another tooth and keep the chain tight.
Did this today and all i can say is FUCK ME these things fly. Gave the P plater in the VS commy a suprise. :roll: :roll:
It seems to have done the trick. Full pedal in 1st an 2nd at about 6500rpm and theres the speedlimit gone.
Author:  swifty_ano [ Thu May 07, 2015 7:41 pm ]
but the rattle lasts for quite a while. Takes about 10 minutes of hard running when it's already warm. I would leave it if it went away sooner
Author:  dhula [ Mon May 11, 2015 9:34 pm ]
Little OT I guess but still relivant I think;
My experiences with oil filters
Ryco --> ticked like a barstard for up to 10 seconds when cold starting, sometimes when warm starting
Another brand (came in a 4wd Products filter kit, can't recall the brand name) --> ticked for a up to 10 seconds on cold start when getting close to oil change time, warm starts were OK.
AC Delco --> No ticks to speak of when cold or warm starting. Maybe the odd "tick tick" and that's it.
