It is currently Mon Aug 10, 2026 10:38 pm
Vehicle: 1994 sierra
Post Posted: Fri May 08, 2015 7:54 pm
hey guys , i just chucked 2 inch leafs in my sierra and long shackles that are just 2 bits off flat bar , it already has a body lift i took it up a few trails that I always go up and nearly put it on its side just seems to go over to easy , would this be the length of the bodgy shackles 115 mm bolt to bolt or just cause there flat bar should i put my stock shackles in i was gunna get some laser cut zook 2 inch shackles but not sure now as i don't want to be rollen over any advice would be great
cheers
Post Posted: Sat May 09, 2015 7:00 am
The lower you can get the body, the better your center of gravity will be.
Long shackles can give you some lift but they also can insert sideways flex which is, from what I hear, kind of scary. Plus, long shackles can screw up steering caster and the pinion angles on the differentials.
If you have 2 inches of leaf lift and the tyres will clear with that, I would - at the least - go back to the original shackles and feel how it rides. If it still feels like it is going to roll, It might be a good idea to remove the body lift.
As you can tell, I am more of a Spring Over Axle (or arched Spring Under) kind of Zuker than a lover of Body lifts and shackles...
I hope that this helps!
-Ack
http://www.acksfaq.com
88, 88.5 SJ413
Post Posted: Sat May 09, 2015 7:28 am
What size tyres are you running ?
Why do you need extended shackles ?
Have you done anything to address some of the problems from the shackles?
Do you need the body lift?
Have you pulled apart you leaf packs and played with the amount of leafs to get it flexing to or at least near the bump stops.
Seems like every mod you have mentioned will make the car less stable, albeit only a little with each mod , it would be cquite a lot all together.
The body lift won't be to bad , but if your running 30's or smaller then it's not needed.
The extended shackles will be doing all sorts of bad things , not to mention raise the whole drive line chassis ect. So if you haven't extended bump stops to run bigger tyres and longer shocks, ect I can't see any reason to run them. Not that I would any way. But there should at least be reason ither than full heck tic lift bro.
If you haven't already , pull the sting packs and remove some leafs to get it flexing better , will make the car less spooky and more stable.
I hope this helps.
Post Posted: Sat May 09, 2015 8:33 am
Thanks guys
ill put the stock shackles back on for starters then ill look into removing a leaf or two?
which leaf or leafs would you recommend removing jack?
cheers
Post Posted: Sat May 09, 2015 10:39 am
How long have you been driving your sierra? Do you actually know its tipping point? If you're new to this, you'll be surprised how far they can actually lean.
My bet is you're getting wheels off the ground and that feeling is unsettling so you think its about to roll, but it probably isnt.
Here's my sierra with approx 5" lift, 31" tyres on 15x7-38mm rims at an angle, which i happily drove out of:
Go through the members section and you'll see many shots just like it.
It's totally normal to be lifting wheels up in the air, and the see-saw feeling you get when it happens is very scary when you first start hitting terrain that does this to your car, but keep at it slowly and you'll get a knack for the feeling, maybe even enjoy it! lol
Post Posted: Sat May 09, 2015 3:01 pm
well i knew the tipping point with a body lift only layed it over twice, but now its just supid i only threw the extended shackles in cause my stock ones are a bit bent
Post Posted: Sat May 09, 2015 4:24 pm
What size tyre are you running, and on what rims?
Low is the new lift.
Post Posted: Sat May 09, 2015 4:58 pm
15 inch rim 30,s
Also steve while your here i need to do my clutch but I'm a little confused about the 18 spline and the 20 spline I've got a sj70 is there any way i can tell without removing my old one?
Post Posted: Sat May 09, 2015 5:18 pm
Can't help with the clutch. I try and stay away from manuals. :D
30's don't need any lift at all, so any lift you're adding is just reducing stability. The tyres are responsible for 2" of lift by themselves. If you don't plan exceeding about a 31" tyre, I'd ditch the body lift.
Post Posted: Sat May 09, 2015 5:36 pm
my tyres are pretty rooted ill replace them with 31s soon
cheers
Post Posted: Sat May 09, 2015 6:15 pm
31's fit with a 2 BL with no suspension lift at all. Or with no body or suspension lift with some guard work and bumpstop extensions. less height, and a car that settles onto its bumpstops are what makes a stable car.
Users browsing this forum: No registered users and 75 guests
