It is currently Mon Aug 10, 2026 1:18 pm
Vehicle: serria
Post Posted: Wed May 13, 2015 7:29 pm
need help with coralla conversion please
Vehicle: 1999 Suzuki Jimny JLX
Post Posted: Wed May 13, 2015 8:07 pm
A bit more info might be handy so people can help you...
Post Posted: Thu May 14, 2015 6:34 pm
What exactly would you like to convert your corolla too?
Or do you mean you want to make your corolla a convertible ?
Or this a corolla some sort of currency I haven't heard of??
Vehicle: Swb Sierra
Post Posted: Fri May 15, 2015 1:52 am
No jack coralla it's a toyada coralla
Vehicle: X-90 + Lwb Sierra + DeVitt +++
Post Posted: Fri May 15, 2015 5:36 am
Convert it at cash converters then put the $$ down on a deposit for a Sierra ?
if you are putting a corrolla engine in a sierra then what engine are you using ? K , T , 2T ,3K, etc etc etc
bit like saying you want to want to buy some teal slacks
Vehicle: WT sierra, GU CRD
Post Posted: Fri May 15, 2015 1:07 pm
Anything after *E70 (apart from the sprinter) should have the engine removed and then converted at Sims.
I love ZD30. :)
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Fri May 15, 2015 1:48 pm
eleteric conversions are easy. i have a 250Kw 2.6 tonne motor ready for ya.
Vehicle: serria
Post Posted: Fri May 22, 2015 7:21 pm
sorry guys want to fit a corolla engine in a seiria
Vehicle: serria
Post Posted: Fri May 22, 2015 7:25 pm
got access to 4k and 2t .and 2 or 3 others
Post Posted: Fri May 22, 2015 8:45 pm
Is there a surplus of anchors?
Post Posted: Sat May 23, 2015 9:18 am
tech, don't bother.
Putting ancient corolla motors in sierras was fine in the early 80's, but it hasn't been a good idea since. They're heavy and the gearbox options don't work well in a Sierra.
I've driven a sierra with a 5K in it, it was torquey but it was a nasty conversion - clearances were poor, the transfer had to be moved back, and It wasn't any better than a G16A, although at the time (about 1995) G16A conversions were almost unheard of.
The biggest problem is it required an engineers certificate to re-register, so the car couldn't really ever be sold without spending a lot of money on it. Made a "cheap" conversion expensive.
Vehicle: Coily.
Post Posted: Sat May 23, 2015 10:14 am
There was a Sierra for sale with a Corolla Motor earlier this year(late last year?),i'm sure they had it mated to the Sierra G/box.I forget where i saw it but it was probaly Gumtree or Ebay.
Post Posted: Sat May 23, 2015 10:19 am
I'm willing to bet it didn't, and it was just a poorly worded ad implying the sierra [i]transfer[i/] was used.
I've never seen or heard of a corolla/sierra adapter plate. I agree it might be the better solution, but a better solution again is to avoid the pushrod/cast iron corolla motors altogether.
Vehicle: Vitara 1994
Post Posted: Sat May 23, 2015 8:40 pm
it's a lot of work for a sideways step imo
Unless one of the other toyota engines is the 22re so you can use the short 1st gear hilux gearbox it's not really worth it.
Otherwise there are much better options these days for engine conversions. the 4age if you want a toyota engine springs to mind (lighter and more powerful than the 2T) and the obvious g16b
Users browsing this forum: No registered users and 69 guests
