It is currently Sat Aug 08, 2026 12:28 pm
Vehicle: MG410 Gypsy
Post Posted: Sun Jul 26, 2015 12:58 am
I have WT centre's with lockers that I want to fit to my NT 1.3 will NT axles work/fit?
Post Posted: Sun Jul 26, 2015 7:43 am
Pretty sure there's a write up in good tech.
Post Posted: Sun Jul 26, 2015 11:07 am
I was looking for it.. no luck.
Post Posted: Sun Jul 26, 2015 11:25 am
Yep they bolt in with no mods. Only thing is a slight gearing difference.
Post Posted: Sun Jul 26, 2015 11:30 am
Thanks shep
Post Posted: Sun Jul 26, 2015 1:09 pm
There is some difference between NT LWB and NT SWB.
bye
Post Posted: Sun Jul 26, 2015 2:51 pm
Also nt drive shaft flange has 8mm bolt holes where wt is 10mm. I just made a 1/2nt and 1/2 wt driveshaft
Post Posted: Sun Jul 26, 2015 3:15 pm
Shep did you just change the flanges on either end?
Post Posted: Sun Jul 26, 2015 6:34 pm
No just pulled the driveshaft in half on the expansion spline.
Vehicle: Suzuki Sierra Trayback
Post Posted: Sun Jul 26, 2015 6:39 pm
N.T have 3.9 ratio and W.T have 3.7.
You could change the diff pinion flanges to N.Track ones, but you'd then have to get your diffs pre-load set up again. Alternatively you could buy W.T tailshaft flanges to go on the diff end of your N.T tailshafts. You'd have to replace uni-joints when doing the tailshaft flange.
Lockers usually run 26 spline side gears to suit c/moly axles, your front N.T axles would be 22 spline. Might be worth doing a side gear spline count to make sure.
Nick
Post Posted: Mon Jul 27, 2015 6:20 am
I thought that the actual housings are different sizes.
bye
Post Posted: Mon Jul 27, 2015 5:57 pm
Early 1ltr ones are smaller.
Users browsing this forum: No registered users and 40 guests
