http://auszookers.com/forum/
WT diffs in NT
http://auszookers.com/forum/viewtopic.php?f=37&t=50622
Author:  4x4xzook [ Sun Jul 26, 2015 12:58 am ]
Post subject:  WT diffs in NT
I have WT centre's with lockers that I want to fit to my NT 1.3 will NT axles work/fit?
Author:  Gwagensteve [ Sun Jul 26, 2015 7:43 am ]
Post subject:  Re: WT diffs in NT
Pretty sure there's a write up in good tech.
Author:  4x4xzook [ Sun Jul 26, 2015 11:07 am ]
I was looking for it.. no luck.
Author:  shep [ Sun Jul 26, 2015 11:25 am ]
Yep they bolt in with no mods. Only thing is a slight gearing difference.
Author:  4x4xzook [ Sun Jul 26, 2015 11:30 am ]
Thanks shep
Author:  cairns27 [ Sun Jul 26, 2015 1:09 pm ]
There is some difference between NT LWB and NT SWB.
bye
Author:  shep [ Sun Jul 26, 2015 2:51 pm ]
Also nt drive shaft flange has 8mm bolt holes where wt is 10mm. I just made a 1/2nt and 1/2 wt driveshaft
Author:  4x4xzook [ Sun Jul 26, 2015 3:15 pm ]
Shep did you just change the flanges on either end?
Author:  shep [ Sun Jul 26, 2015 6:34 pm ]
No just pulled the driveshaft in half on the expansion spline.
Author:  flymaster [ Sun Jul 26, 2015 6:39 pm ]
N.T have 3.9 ratio and W.T have 3.7.
You could change the diff pinion flanges to N.Track ones, but you'd then have to get your diffs pre-load set up again. Alternatively you could buy W.T tailshaft flanges to go on the diff end of your N.T tailshafts. You'd have to replace uni-joints when doing the tailshaft flange.
Lockers usually run 26 spline side gears to suit c/moly axles, your front N.T axles would be 22 spline. Might be worth doing a side gear spline count to make sure.
Nick
Author:  cairns27 [ Mon Jul 27, 2015 6:20 am ]
I thought that the actual housings are different sizes.
bye
Author:  flymaster [ Mon Jul 27, 2015 5:57 pm ]
Early 1ltr ones are smaller.
