It is currently Sat Aug 08, 2026 1:16 pm
Vehicle: MG410 Gypsy
Post Posted: Fri Jul 24, 2015 3:03 pm
Hi all, so i have recently purchased a NT 1.3 LWB and i want to use the trasnfer case out of my WT 1.3 sj70 as it has 6.5.1 gears in it.
do i need to change Flanges or anything? is it a straight bolt in?
Post Posted: Fri Jul 24, 2015 3:14 pm
flanges have different bolt patterns and will need to be swapped
Post Posted: Fri Jul 24, 2015 3:36 pm
Thanks tanshi.
No other changes
Post Posted: Fri Jul 24, 2015 3:54 pm
Does your WT transfer case have a handbrake drum?
Usually NT use a transfer case drum handbrake, where as WT handbrake are usually rear wheel brake drum. Might need to sus out how your going to keep a handbrake.
Post Posted: Sat Jul 25, 2015 2:24 am
WT has rear wheel brake cable.
What have others done to fit handbrake with WT case?
Post Posted: Sat Jul 25, 2015 6:51 am
Id suggest two options, both a fair bit of stuffing around..
1) put your 6.5 gears into the NT case and keep your handbrake setup as it is. Good opportunity to refresh the bearings and bushes etc.
2) pillage a set of rear brakes and handbrake setup off a WT and convert yours to rear wheel handbrake.
Option 3), not the most suggestible. Travel with a brick you can lodge under a tyre when you park..
Post Posted: Sat Jul 25, 2015 9:29 am
Option 4: Fit the nt drum brake to the transfer case when swapping flanges.
Hardest part is you may need to tap a thread into the holes for the 4 bolts to hold the backing plate in place.
Post Posted: Sat Jul 25, 2015 10:03 am
Option 3 and 4 sound like the best solution.. Didn't know you could retrofit the drum handbrake!! Suppose it makes sense, same casting for the case
Post Posted: Sun Jul 26, 2015 9:59 pm
Thanks for the suggestions.
look like I'll give option 4 a go and fit the NT drum brake to the case.
Users browsing this forum: No registered users and 56 guests
